N2o on stock bottom lt1
Old 03-02-2009, 01:41 PM
Robwhartlt1's Avatar
Hey guys just wanted to find out if anyone new if I would be able to run a100 shot on my car with stock pistons.
Robwhartlt1 is offline
Old 03-02-2009, 02:26 PM
96m6lt1's Avatar
100 shot is a walk in the park, just be sure you have good plugs tr55 .032-.035 gap
have a good time spankin your competition!
96m6lt1 is offline
Old 03-02-2009, 03:32 PM
slomarao's Avatar
a 100 shot should be no problem. past 150 is when you starting walking on thin ice.
slomarao is offline
Old 03-02-2009, 04:21 PM
I think that will put me in the low 11s right.
Thank for all your info
Old 03-02-2009, 04:47 PM
c5formula's Avatar
your gonna want to run atleast a ngk tr6 plug at .035-.035 rang the tr55 is more an NA spark plug the tr6 is more a nitrous plug. you may need higher octane fuel depending on what you compression ratio is.
c5formula is offline
Old 03-02-2009, 05:03 PM
Where do I buy the plugs and I have a chip that motorvation custom made cause the to me I can't tune the car any other way. Is this true.
Old 03-03-2009, 09:52 AM
Z-RATED94's Avatar
Do go with the TR6's, which you can pick up at just about any auto parts store. As far as tuning, you can pull timing with a couple of different ignition boxes, and leave your tune alone. I went with the Mallory 685. Its wired to the nitrous system "on" switch. When you hit the switch to make a nitrous pass the box pulls whatever you have the timing retard set at.
Z-RATED94 is offline
oldschool
02-09-2016 09:21 PM
Jlo
02-03-2015 09:41 PM
jb4xx
02-02-2015 10:00 PM
97z28k&N
01-09-2015 04:58 AM
DubbyZ28Camaro
08-04-2002 12:53 PM
Quick Reply: N2o on stock bottom lt1
