has anyone run a 250 shot on a stock intake ?
Old 03-11-2010, 09:51 PM
tsnlarue's Avatar
im running the plate set up not so not sure if it will go that high but i got the pills and wanna try anybody do 250 safely on the stock intake?the car is a 96 lt1
tsnlarue is offline
Old 04-16-2010, 07:51 AM
Revolutionary's Avatar
I run that and it does fine. Make sure your lines (especially if you are running -3) are bigger than the jets you use though. I know it sounds basic but on the lines I had I had to drill the ends of the lines out a little as they were only ~.080 which would not be good if you wanted to run a .082 jet.
Revolutionary is offline
LT14LIFE
02-09-2015 09:35 PM
birdblack
12-30-2014 06:59 PM
Catmaigne
12-25-2014 12:16 PM
Noenav
12-06-2014 07:35 PM
thenewkid
11-27-2014 09:41 AM
Quick Reply: has anyone run a 250 shot on a stock intake ?
