AnoThEr Ring Gap Thread~!
ok. I need some help deciding on what ring gaps to run.
I called Perfect Circle and they recomened about .018" for the top, .021" for the bottom.. That is also what Federal Mogul recomended.
but I see everyone running .025" or so.. I want to run a little nitrous (no more than 150) here is my motor. and advise would be great. Thanks
180* T-Stat
CC Hardened Pushrods
Mid-Tube PaceSetters
Flowmaster 80 Series Catback Exhaust
SLP CA Induction
MSD Optispark
MSD Coil
Gutted Cat
CC 1.6 RR 7/16" NSA
Eagle Cast Crank 3.75" stroke
Eagle I Beam 5.7" Rods W/ARP CapScrews
SpeedPro Hyper Pistons .030" Over -12CC Dish
Perfect Circle Rings 40564CP .030"
11.6 SCR / 9.0 DCR
LE2 Heads
LE Ported Intake Manifold
LE2 383 Billet Cam
Ebay Stage III Clutch
EGR Delete (May Need Tuning Here?)
Aluminum Intake Elbow
AEM Wideband
All New Bearings
Brass Freeze Plugs
LS7 Lifters
TB Coolant Bypass
Secondary Air Delete
180* T-Stat
SLP CA Induction
MSD Optispark
MSD Coil
Gutted Cat
CC 1.6 RR 7/16" NSA
11.6 SCR / 9.0 DCR
LE2 Heads
LE2 383 Billet Cam
AEM Wideband
All New Bearings
Brass Freeze Plugs
LS7 Lifters
TB Coolant Bypass
That would be too tight for me to be comfortable with if i were to run nitrous. That sounds closer to a NA setup. You might want to run them larger. Like in the .022/.024 range ore even slightly bigger. Thats closer to a mild nitrous setup. I know my JE's stated specific gaps with mild to race boost and nitrous setups. The sheet came with my pistons.
Ken R.
Ken R.
I ended up going with about .025 on top, and .028/.029 on the second ring.. I would rather get a little blow buy on cold starts for a while and lose a tiny bit of compresson that have to rebuild the thing again.. I think my numbers are prety good. I cant understand that chart from perfect circle.. everything is so so tiny on there..(just reslised that the chart was posted in a diffrent thred.. but it was like .0075)
