100 Shot
Old 07-10-2008, 09:05 PM
97sscamaross's Avatar
100 Shot
I just put a dry shot nitrous kit on my car and was wondering if it's safe to run a 100 shot on stock internals.
97sscamaross is offline
Old 07-10-2008, 09:22 PM
Z-RATED94's Avatar
If the motor is healthy I would say yes. Did you get all the safty stuff to play it safe? Are you going to dyno it to check the A/F? My bolt on H/C stock shortblock motor came up with 468rwhp on a 115shot.
Z-RATED94 is offline
Old 07-11-2008, 01:36 AM
it's a pretty basic kit, it has an arming switch and a throttle switch. I plan on getting a window switch for it and possibly a fpss. But I'm going to get it dyno tuned when I get the extra cash.
Old 09-17-2008, 08:49 PM
remaxracer45's Avatar
z rated who dyno tuned your setup?
remaxracer45 is offline
Old 09-18-2008, 10:31 AM
Z-RATED94's Avatar
Speed Inc. a few years back. Ion did the h/c start-up tune which nice work also. Speed doesn't do obd1 anymore but Ion has been known to use a few different shops dynos, including Speeds.
Old 09-18-2008, 02:34 PM
slomarao's Avatar
i would be careful with a dry kit on a lt1. Computer cant keep up with the n2o.
slomarao is offline
Old 09-18-2008, 05:54 PM
karpetcm's Avatar
Just make sure you got the right plugs and a good tune specifically A/F and timing, thats fairly basic. Id say wet or dry as long as you know what your doing and you have a healthy motor you shouldnt have any issues and can go a bit higher on the shot. With a wet and good tune(amoung other things) for example you shouldnt have any problems at 150 shot which is what i ran on my 93Z with 218,000 miles no issues what so ever.
karpetcm is offline
Henson071
09-18-2015 04:01 PM
nd4spd200
08-21-2015 09:30 AM
Cam's maro
08-11-2015 07:45 AM
08-07-2015 08:52 AM
NewsBot
08-03-2015 02:40 PM
Quick Reply: 100 Shot
