LT1 Dyno Tuners in So Cal
I've called Haddad Motorsports 2x and have left messages. Yesterday they didn't call me back. Today, they said they got my message... said they would call me back... no call.
Is there a reliable Dyno Tuner for LT1s in So Cal?
I got a response from Haddad. It takes a while to get a hold of them, they did a decent job before which is why I'll give them another shot.
The Camaro is a 1995. Kevin, I may have a cable since I used to read the ECM with Freescan. If all fails with Haddad, I'll contact you and set something up. Do you need a dyno? Do you work with the factory O2 or do you tune with a 5v Wideband?
Thanks.
Thanks.
Kevin, Thanks. I do have Sept 11 set up with Haddad. However, if that falls through, then I will definitely contact you. Thanks again. I have to be in Vegas on 9/16 for a run so it needs to be tuned up before then. Phew! Not much time.
