Need LT1 fuel rails modified, who can?
I need an AN fitting welded to my LT1/LT4 fuel rail. Any recommendations? Would be great if between Dearborn and South Lyon.
Thanks,
Kevin
69 Camaro, LT4 T56 9" Mini tubbed, 315/17 & 245/17 Budnik Hammer 6pt cage Baer Brakes Vintage Air DSE suspension
Thanks,
Kevin
Re: Need LT1 fuel rails modified, who can?
Does it have to be welded? Could it be tapped? If it can be drilled and tapped i can do it. If it needs to be welded then you can drill it and have starlite welding in redford weld it. Steven
I can weld it for you. I work in dearborn and can turn it around for you next day. I live in the romeo area, i'm sure you don't want to come to my house to have it welded up. 586-255-3426. Mike.
Mike,
Thanks for the offer. One of my neighbors says he can do it (at work). Must have someone there that can do it. I will let you know if it doesn't work out.
Kevin
Kevin
hotrodyou1
12-20-2014 10:05 PM
07-04-2005 05:00 PM
