Had it with electric water pumps!
I finally get my M6 to 4L60E transplant done at 6:00 Wednesday for a car show at work on Thursday. In addition to going through the trans I ending up going through engine, and axle too. Seeing how the entire driveline was apart I figured I should put some miles on the car before I make the 33 mile trip to work. I get 3 miles away from my house and overheat the engine. Sure enough my CSI electric water pump took a dump. This pump was installed early spring and has less than 100 miles on it. I was able to do only slightly better with the previous pump (a Meziere). At least the Meziere lasted two years of very limited driving.
Im a little ticked off!
Am I the only one with this experience? I think I'm switching back the gear driven pump. I'll take my chances with a broken timing chain.
B.T.W. I modified my timing cover for a Pete Jackson gear drive, so I'm in the market for a 95-97 timing cover, water pump, and drive gear.
Brian Falzon
10.54 @133.8 MPH
with a T56, 4L60E transplant is almost complete!
Brian Falzon
10.54 @133.8 MPH
Location: Windsor, Canada: Home of the FASTEST LT1 & LS1 6 spds :)
brian, sorry to hear your frustration with the pump, i hae maybe 2000 miles on mine, so far it is ok (quickly touching wood).
also got the lockout from kevin, thanks again, i plan on installing it this week. i was gonna go racing today, but decided not to, weather is $hit and i didn't feel like driving almost 4hrs to thenearest track that i could make 5 or 6 passes at. too many events this weekend
i'll let you know how it goes.
Brian, keep us updated on your progress with the new 4L60E. I'm interested in how well it's gonna hold up. I hope you put a tranny cooler on it. Good luck on the pump.
hchap63@hotmail.com
01/SS, Black A4, TR224/112, ARE stage 2 heads, lid, FTRA, PMAF, PTB, Grott LT, true duals, NGK, ASP pulley, Vig 3200, LCA, poly TAB, Convo pros, ET Streets, 3300 raceweight. Little bit of juice..
Best ET: (All bolt ons) 11.496@116.42 (1.52)
Current best after Head & cam & nitrous:
10.88@124 (1.60)
Motown Muscle King of The Hill winner 6-8-02. Want some? Get some!!
RIP #3 Dirty Dale!!!
hchap63@hotmail.com
10.88@124 (1.60)
Thanks,
For as long as the water pump lasted, the 4L60E worked great. I'm running two super coolers. Even though I overheated the engine, the trans barely got over 140. Yeah, I'm kind of interested to see how long it will last too!
Brian Falzon
10.54 @133.8 MPH
with a T56
No runs with the new 4L60E
[This message has been edited by Zone (edited July 28, 2002).]
Brian Falzon
10.54 @133.8 MPH
with a T56
Thanks Mike,
I had a post on the for sale section. I ended up geting the cover, pump,and drive gear all from the same guy.
Redbird,
Possibly was an electrical issue. I'm woundering if it was a heat problem? I had a custom aluminum fan shrowd that put both fans at the bottom of the radiator. The shroud blocked off any air from hiting the pump. Thinking about it, the pump didn't last very long after I installed the trans coolers.
Hmmm!!!!
I hope your Mez keeps pumpin, but when I say I got 2 years of limited driving out of it I meant (drag racing)!
[This message has been edited by Zone (edited July 29, 2002).]
Redbird,
Hmmm!!!!
stockssn2o
05-25-2015 08:54 AM
