[Michigan] Fast Restored Ruttman Spider SS Minibike
SOLD!
This is a restored Ruttman Spider minibike. The motor is a newer 6 1/2 hp clone motor. I have way to much into this minibike so theres way to much to mention.........runs on 110 race feul and royal purple oil.......runs excellent and vary dependable.....with the gearing thats on it now it will do about 52-54mph.........it will flip you over backwards if your not careful....could change the gearing and go faster if wanted......$1,000 firm
Aluminum billit rod
Aluminum billit flywheel
Bored and epoxied carburator
Carb spacer
newer valve springs
head is ported and milled .050
newer push rods
Header pipe
All grade 8 engine bolts..
better clutch with hardened keyway
Aluminum billit rod
Carb spacer
newer valve springs
newer push rods
Header pipe
Re: Fast Restored Ruttman Spider SS Minibike
Will seperate
Complete motor with header pipe and clutch.......$600
Complete Rolling chassi ................$600
$950 complete firm
$950 complete firm
