Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
Best LT1 bolt on Power adder (No SC or Spray please)
Old 07-13-2007, 07:21 AM
FutureZMan's Avatar
Looking to do some light mods to my car, Set of rims, and some small stuff.
Just wondering what the best Bolt on power adder will be.
I was thinking 52MM TB with foil, but have no idea the number gain.
Maybe 4:10's although it wont add power, it will make it feel like it does lol.
I already have a CAI, Any ideas?
FutureZMan is offline
Old 07-13-2007, 08:50 AM
JoeliusZ28's Avatar
an LT1 isnt an LT1 worth having until you put longtube headers on it they wake right up.
JoeliusZ28 is offline
Old 07-13-2007, 10:08 AM
SSpdDmon's Avatar
x2 on the headers.
SSpdDmon is offline
Old 07-13-2007, 11:06 AM
IrocSS85's Avatar
gears/then headers. 4:10 only for T56 cars. got cai yet? forget about the throttle body/foil until you go into the engine. wont make SHIZNIT difference till then. even then, its arguable if its worth the cost or not.
IrocSS85 is offline
Old 07-13-2007, 05:18 PM
94_Z28_ragtop's Avatar
Headers first. Induction mods don't do much good until you can get the extra air out of the engine. Exhaust, then induction. I learned the hard way. Then 2800 rpm stall if it's an auto. I got my 1994 convertible to run 12.85 @ 105.x with just bolt ons and no weight reduction.
94_Z28_ragtop is offline
Old 07-13-2007, 07:12 PM
stereomandan's Avatar
I would wait on gears until after headers, catback and CAI.
My $0.02. Even a stock LT1 isn't easy to hook well on street tires. 4.10's make it even harder. If you have sticky tires, the 4.10's will get the most out of them. (for a M6 tranny)
Dan
stereomandan is offline
Old 07-16-2007, 08:58 AM
JoeliusZ28's Avatar
ive run 13.5s with the stock 3.42
Im also running out of gear in the quarter as if I have a 4.10 though. (this is a mystery ive been trying to solve about my car).
but definitely headers before gears. I wont change my gears because I think if i run anything but stock ill bust the thing. I think my 10 bolt is on borrowed time as it is. my spec 3 beats the hell out of it.
Old 07-16-2007, 09:33 AM
IROC5.7TPI's Avatar
I wouldn't do a gear swap, just because the 10 bolt is weak and as said it won't hook anyways. Then you'll be looking for a set of sticky tires ultimately breaking the rear end.
Go with cold air, exhaust, headers and a good tune.
IROC5.7TPI is offline
Old 07-16-2007, 10:22 AM
IrocSS85's Avatar
well you cant really compare my car, cause its stalled auto. which will launch easier and not kill rear ends as quick. BUT, my 3:73 lasted 5K miles behind my Iroc (swaped in a 4 gen rear axle) and around 40 1/4mi. runs. most mid to high 12's. 2 runs on nitrous that were 1/8mi runs would have been high 11's. then 6K miles behind my 383 LT1 and around 20 track pass's. in my 95 with the 3:83, it went lots of `1.8's before I got my 3800 stall and since saw 1.6's and one 1.56 sixty foot. did I mention that I got this rear axle/gears USED? and I know the guy I bought it from beat his car. he was parting it out cause he blew the engine. your car is NOT goin to put anywhere near the kind of power mine has, so thats why I think you'll be fine. and, you can reap the bene's of 4.10's ANYWHERE in the rpm band except from a dead stop. where yes, it will make it harder to hook up.
but you werent talking about making the car a drag car. or serious street racing. Im ASSuming fun street driving is all you'll be doin with it?
if so I still say 4.10's first, headers/ypipe/catback all at once second.
but thats just my humble opinion.
chris
IrocSS85 is offline
Old 07-16-2007, 12:41 PM
exgmguy's Avatar
Gears and tires alone can make a stock car run great. People will wander over and look under the hood if you run just a decent time without making a ton of noise, big burnout, etc....
exgmguy is offline
mdacton's Avatar
bolt some heads on it too
mdacton is offline
HectorM52
07-30-2017 11:46 AM
10-31-2016 11:09 AM
InfernalVortex
01-17-2015 09:35 AM
XtremeLt1
09-13-2002 08:50 PM
Quick Reply: Best LT1 bolt on Power adder (No SC or Spray please)
