Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
[Michigan] #1039 1997 camaro ss black 6 speed $8300
Old 03-08-2012, 06:34 PM
Black 97 SS's Avatar
Pictures by jski_2067 - Photobucket
#1039 1997 CAMARO SS BLACK 6 SPEED $8300 OBO
Im located in Michigan.
The car has 105,000 on body but drivetrain has been all changed. I have over 20k in this car and i know i won't get it out but i dont wanna part it out, its to nice of a car. Heads/cam moter and complete drivetrain.Car has never been in a wreck and is stored winters. I did all the modifications about 18k ago, while engine was out i repainted engine bay and polished alot of aluminum under hood. You can eat off the engine and underneath of car. NO RUST anywhere. I have orginal running motor and factoy parts still for car. The car has been dyno tuned and put 371 RWHP, 347 RWTQ. I just put a new AC pump and fresh charge last season.
HERE IS WHATS DONE:
-fresh shortblock stock pistons, rods, crank, ARP studded 2 bolt mains, ARP rod bolts
LE1 Elliot port works heads with 1.56-2.00 valves
Matched intake by Elliot port works
Comp Cam CC306
Comp Cam 1.6 Promagnum Roller Rockers
Comp Cams Hi Tech push rods
impala head gaskets
58 mm Holly throttle body
30 lb injectors
Racetronics hi flow fuel pump
MSD Optispark
pacesetter coated longtube headers and y pipe
TOTL exaust and cutout
mcleod clutch 7500 rpm disc
LT4 presure plate
SFI approved steel flywheel (cant remember name but it was $400 new)
mcleod blow proof scatter sheild
3.5" Strange driveshaft with crome molly joints
Strange S60 with 4:11 gears
Pro 5.0 shifter
SUSPENSION/BRAKES:
C5 Corvette front brakes and braided brake lines
Sphon chrome moly tublar lower control arms, Panhard bar
Sphon 35 mm front sway bar
BMR adjustable Torque Arm and Transmission relocation Brace
SLP springs/ Bilstien shocks
BMR welded subframe connectors
SLP driveshaft safety loop
new wheel bearings
SLP line lock
SLP air intake (have original as well)
Chrome Zr-1 9.5" rims
INTERIOR
I had the center console, kick panels, rear sail panels, and trunk panels wrapped in leather and stiched professionally. Really makes the car feel nice inside. The drivers side seat as the normal wear but the other seats are like new. White faced gauges, C6 corvette ****
Exterior
I have had both bumpers and hood repainted (since these cars pick up so many rock chips) The paint work was done by the MSX internationals Paint shop manager. This company painted all the GM International auto show cars for several years as well as producing most of the body parts for the first Vipers.
Black 97 SS is offline
sdn1997rs
12-30-2014 08:30 AM
bernie1951
12-10-2014 10:03 AM
siguy
11-27-2014 10:07 AM
ChrisFrez
11-23-2014 10:33 AM
Quick Reply: [Michigan] #1039 1997 camaro ss black 6 speed $8300
