Houston we have a problem
It got late so I nixed the Friday night plans for Numidia and went to my local track (Maple Grove) to get some runs on the firebird. Got to make 3 T&T passes. 12.20, 12.05, and 12.30. My lights and 60' were all over the place too. Houston we have a problem. 12.0x is where the car shoud be for the DA. Came home and had some left over wings. This was my first time out as a grandpa. Hummmm maybe I'm too old to race.
So what do I do today?
Numidia big bucks race
Maple points race
And which car firebird or the mustang.
Decisions, decisions.
Well I have a few hours to decide.
Maple points race
Need more data!
Did your 60's pick you when your ETs picked up? How was your MPH at midtrack? Where were picking up at? Is the car running the same temp? what about the trans temp?
You were at a TNT, I assume all the street tire cars hurt the starting line, could make your RTs look bad, if your spinning even slightly it would result in you not lifting the front and bringing the wheels out of the beams the same. I assume you were going deep? might want to do some testing going shallow so you know the car is being set in the same spot until you get yourself consistent with the tree, then go bad to going deep.
Not sure at MG, but with the temp changing quickly Dew can be an issue, just because it gets cooler doesn't mean the air gets better, you can't burn the water droplets! It may be cooler, but there can be less oxegen in the air?
Did you figure anything out over the weekend?
I ran at the YB Nationals down at Cecil all weekend. Friday night T&T and Saturday bracket race left me with RTs all over the place and my ET picked up each run I made.
Sunday I decided to run Pro Dial (bracket race with a handicapped pro tree) to see where the heck my RTs REALLY are. The answer? DEAD LATE. .125, .170 and .0130. Rick is thinking I need to deep stage this car as it isn't leaving as hard as my Nova did.
I tossed out friday nights runs. I believe it was mostly due to poor track conditions. I was backed out of the water box on my first run for an antifreeze cleanup. I did spin on the line and mid track. Data was a mess. I went to Numidia the next day and ET's were a lot closer. I did notice that I'm having issues footbraking at the correct rpm. I had time to look down at the tach and I was 600 rmp lower that what it should of been. Hello .070 lights. lol.
Jax, i agree go deep girl. Watch how Bud McNasby deep stages with the autostart and deep not being honored. I deep stage the firebird the same was just not as graceful as Bud.
Watch the rollout at Cecil. Close to the center wall rollout is simular to Atco. As you move over to the outside wall rollout increases bigtime.
I am also having trouble holding the rpms steady. I found out that I can't hold the car higher than 2700 by accident.
I was the only one in the tower Friday so I didn't get a chance to talk to you. I did notice you were waiting to jump in and then go deep after the other car staged. Try going in just a bit quicker, might give you a bit more time to get up on the convetor and set your RPM before the tree drops on you?
I don't have an issue going deep even when the other car is fully staged. I sit just in front of the prestage beam. When I'm ready (not as long as Bud lol) I bring the car up to launch rpm and do one roll up to fully deep staged.
I'm going to install a throttle set device shortly. Fellow racer designed a killer setup and my car will be the first fuel injected application. Device is legal for foot break races.
I'm not saying he isn't good at it. He is AWESOME at it. For me, it's no issue because I know what he does so I just went all the way in. For someone that doesn't know, they would have been sitting there with their pre-stage bulb lit waiting - at least until the starter waives the other driver in.
I don't doubt that I couldn't get in deep without a problem. Perhaps I should try it before I rule it out all together. I'm still working on a solid routine once I roll into the water anyway.
mark0006
02-03-2015 05:12 PM
bonniew
Events and Cruise Spots
01-18-2015 01:14 PM
