Your LT4, how much HP.
Been a lot or talk about the LT4's. But I can only find a few hp numbers. If you have a real LT4 or upgraded LT1 to 4 specs. please list you hp.
Re: Your LT4, how much HP.
Unless you havea real Camaro SS, Firehawk, or vette with an LT4, its not worth convering. You can make more hp from a aftermarket heads and cam then converting to a LT4.
The reason you don't see much in the way of LT4 HP is because the LT4 engine was only installed in less than 130 97 SS's and Firehawks. While others may have done "LT4 conversions", few, if any are TRUE LT4 conversions. Most are limited to the LT4 intake, LT4 heads and LT4 HOTcam, which is not even the cam used in the stock LT4's. They aren't making all the other changes like the cambered piston rings, undercut and rolled crankshaft, higher compression pistons, dual-mass torsional damper, etc that are included in TRUE LT4 engines.
A magazine article by More Performance claimed 429HP for an LT4 conversion, but that was on an engine dyno, all accessories stripped, numerous additional tweeks, including a multi-1000 dollar aftermarket ECU, etc.
To put Fred's comments into perspective it is becomming almost routine for shops like Advanced Induction and Lloyd Elliot to do ported LT1 head and cam packages that deliver 400+RWhp through automatics which is way over 429 crankshaft.
The Corvette documentation claims they had the dual-mass damper. I doubt they would nave made a new one specifically for the F-Body with such limited production, so its possible the F-Body LT4's used the LT1 damper.
Should have left it alone.
The grandsport registry has a dyno page w/ a lot of LT4s w/ various mods. Good source for numbers.
http://grandsportregistry.com/dyno.htm
Sorry for the late response, been out of state all last week.
Ray86IROC & Denny McLain, thanks this is exactly what I was looking for.
Injuneer, even though I am aware of all this, I still appreciate the input.
For all of you, all out HP freaks, it may be hard to understand why anyone would want to do this specific upgrade. So I thought I'd list a couple reasons.
1. I already have an all out performance car, in my 84.
2. I think of this 97 SS as more of a grand touring car then an all out sports car.
3. As, some what, of a collector car I'd like to keep it mostly chevy parts.
4. The stock LT4's are getting around 300rwhp. Which is 50hp more then my stock LT1. With the addition of good headers and maybe the Hot Cam they're in the 325 to 350rwhp range.
5. So this could be 100+ hp in a nice streetable emission friendly package, without a lot of exotic tuning.
6. And finally I already have the LT4 heads, so why not?
Thanks again for all the responses.
Not to hijack this old thread, but you gained 32 rwhp just by upgrading heads on an otherwise bolt on engine with stock cam? How was the torque? Happen to have the dyno graph, I would love to see what the curves look like. I may have a head gasket going out, and figured might as well get the heads ported while they're off, and was curious as to potential gain on LT1 with roller rockers, since the stock Lt4 cam is almost the same as LT1 but with 1.6 rockers.
Your best buzz for the buck will be to bump up the cam along with redoing the heads as I went straight to a 396 instead of just doing a cam. If I had bumped up the cam I'm very confident it would have made around 400rwhp or even a little more.
NewsBot
09-14-2015 02:02 AM
sleeperZ96BT
09-09-2015 08:28 AM
