95 Wiring Harness
Old 09-09-2020, 09:32 AM
weedog's Avatar
95 Wiring Harness
I forgot to also ask if the wiring harness out of a 95 Z28 the same as the 97 Z28 and if so will it plug into my computer. Thanks Again
weedog is offline
Old 09-09-2020, 10:12 AM
Re: 95 Wiring Harness
Are you wanting to use a 1995 engine harness in a 1997 chassis with a 1997 LT1 and PCM?
95 harness will plug into the 97 PCM. TThere will be mismatches with the 1997 body harness connections: Will need to be repinned.
From Shoebox
http://shbox.com/1/harness_connector_faces.htm
You really need to add a “SIGNATURE”.
There will not be any connections on the 95 harness for the 97’s crankshaft position sensor, after-cat O2 sensors, the EVAP system vacuum detection switch, serial data connection. The 95 ignition coil connector will not match the 97 coil.
From Shoebox, marked in red to show differences from 95 to 96/97
4th Gen LT1 F-body Tech Articles
Injuneer is online now
Old 09-10-2020, 01:45 PM
weedog's Avatar
weedog is offline
MikeT123
Parts Wanted
02-24-2016 06:44 AM
GRNcamaro
Parts Wanted
10-10-2007 05:35 PM
A_person_with_a_car
Parts Wanted
07-21-2007 11:35 AM
95okz28
08-12-2005 01:25 PM
Stekman
08-23-2004 09:08 AM
Quick Reply: 95 Wiring Harness
