Yellow toped injectors, stock or not?
i was wondering if anyone here can tell me how i can tell what size injectors i have. If possible if anyone knows the colors that correlate with pounds per hour, i would greatfully appreciate it. My tops are yellow, is this stock or not?
Re: Yellow toped injectors, stock or not?
Accels are what you probably what you have. Here is a link to some http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW hope this helps.
Why do you have larger injectors? You don't have any mods that require you to have larger injectors. Do you have a tune for the injectors? If not that can cause some problems.
I didnt put them on, the guy who owned it previously im pretty sure he was using spray on the car, so i guess that was part of his setup. I want them out, or would it be better to tune for them, is there a gain of hp in a tune of injectors on a stock car? And will i be able to see the "stamped" size with on them without taking the fuel rails off?
10-31-2016 11:09 AM
stockssn2o
05-25-2015 08:54 AM
