Will this be enough?
Hey guys, I am looking for 400+ RWHP and close to the same for TQ. My goal is 420's - 450's on engine, with 410 - 450+ TQ. I knw down the road when I do a 383 motor no prob, but what about with my regular LT1?
This is what I am looking at so far.
AFR 195 (LT4) Heads
Ported to match (LT4) Intake
Custom Grind Cam (maybe similer to the CC306 cam)
255 liter Fuel Pump
30 lb. Ford Injectors
Aeromotive AFR
58mm Holley T-Body
Comp R Lifters
AFR Hydra-Rev Kit (for extra insurance)
Chormoly Push-Rods
GM (LT4) 1.6 Roller Rockers
Delteq Coil Ignition set-up or Direct Hits Coil Ignition
Custom Computer Tuning
I think that's about it. I may have forgot something. Do you all think this will come close to me goal?
AFR 195 (LT4) Heads
255 liter Fuel Pump
Aeromotive AFR
58mm Holley T-Body
Comp R Lifters
Chormoly Push-Rods
Re: Will this be enough?
Originally Posted by Wildwill2855
I promise it wont make 380 rwhp or anything near that you can safely say 320-330rwhp but not 380 hell everyone would have that setup most likly
feel free to correct me if im wrong no harm intended.
the LT4 kit says 425+ HP, but that's with all kinds of bolt ons. as for your setup, i didn't see headers in there or any exhaust work. they're kind of a given when you port the heads. if you want that much power you'll probably want to replace most of your parts with forged parts so you won't be picking them out of your engine piece by piece later. forged is also very useful for spray, and that'll definitely get you into the 450RWHP range
Thanks for the reply, I also already have JetHot LT's, X-pipe, and Bullet mufflers. So the exhaust isn't going to be a problem. I plan on going forged internals in the future, just not right now. I am trying to get everything power adding right now and also finish up my suspension before I rebuild the motor. So that way I can do it all at one time.
Does anyone else think these will get me in the power range I am looking for?
