will about a half quart of oil over full hurt seals?
Old 06-23-2004, 07:57 PM
TexasTechTA's Avatar
accidentally filled the oil up a little too much when i added a can of RESTORE. and it is abotu a half quart too full. Will this cause any leaks or damage any seals?
TexasTechTA is offline
Old 06-23-2004, 08:12 PM
DonHood's Avatar
Re: will about a half quart of oil over full hurt seals?
I'd be more worried about what you put in it, and not so much about the amount. I've never heard anything positive said about oil additives, especially ones with Teflon, which I'm assuming the 'Restore' uses.
DonHood is offline
Old 06-23-2004, 08:29 PM
MY91Y84's Avatar
ive used that stuff..dont worry about the level, in the 500 miles it suggest running itll be absorbed into the seals and restore cylinder pressure if needed...there are gonna be people that say it doesnt work but it does, ive seen it with my own eyes....
as most of you know SBC heads tend to make cloudy startups...my old sbc heads did that used this stuff never did it again....cylinder 3 and 8 were 18-20 psi below the other six and they werent consistant....i used a can of that stuff drove the 500 miles on a sat afternoon and tested the pressures again..not only were the to low cylinders up but it was a max 4 psi variance in all 8...that stuff does work.
MY91Y84 is offline
Old 06-23-2004, 08:33 PM
yea I have been running it for about 2k miles justa little full. The oil pressure is great. anyway I am using mobil 1 syn with it. Any harm done?
Old 06-23-2004, 08:38 PM
gb95zconv's Avatar
If it were me I would drain it out and put the right amount of Mobil 1 in it without the Restore......at least drain it down to the proper full level. No harm done though.
gb95zconv is offline
Old 06-23-2004, 09:11 PM
unvc92camarors's Avatar
used restore in my v6 and it stopped burning just that little bit of oil
only did it once or twice though in it and it still doesnt burn any
just did it in my z28 now too, same as you, with mobil 1 syn.
i would say don't worry about it imo
like said, the restore will probably be absorbed in a little bit
unvc92camarors is offline
Old 06-23-2004, 09:27 PM
grygst76's Avatar
no harm done IMO.. but fix in a can is just what it is... I did and done it before my self, be careful next time.
grygst76 is offline
Old 06-23-2004, 09:34 PM
1racerdude's Avatar
Add two cans of compression while you are at it. HEE HEE
1racerdude is offline
Old 06-24-2004, 04:12 PM
Kevin97ss's Avatar
I'm not going to comment on the additive but the overfill is an issue. It has nothing to do with seals with a slight overfill(1/2 quart or less) but with aeration. Even just a 1/2 qt extra can be whipped up by the crank and cause a loss in oil pressure. You may not see a problem if you drive the car easy on a daily basis but if high RPM is your thing it will be trouble.
Kevin97ss is offline
Old 06-24-2004, 04:17 PM
disco192's Avatar
I ran Restore in my old saturn and in my moms mini van. I ran a compression test before/after on the saturn and the compression did become more stable.
The Saturn had 130k miles and with synthetics, i got 41 mpg on the highway.
disco192 is offline
HectorM52
07-30-2017 11:46 AM
DirtyDaveW
03-15-2015 07:01 PM
94Z28LS1toLT1
01-15-2015 07:18 PM
NJLT1SS
09-11-2002 02:29 AM
Darth Xed
13
07-22-2002 12:45 PM
Quick Reply: will about a half quart of oil over full hurt seals?
