Welcome to CamaroZ28.Com, the ultimate Source for Camaro enthusiasts! Here you can join over 90,000 Camaro enthusiasts from around the world discussing all things related to Camaros and more. You are currently viewing as a guest which gives you limited access to view discussions
To gain full access to our forums you must register for a free account. As a registered member you will be able to:
Participate in over 40 different forums and search/browse from over 5 million posts.
will about a half quart of oil over full hurt seals?
accidentally filled the oil up a little too much when i added a can of RESTORE. and it is abotu a half quart too full. Will this cause any leaks or damage any seals?
This ad is not displayed to registered members. Register your free account today and become a member on CamaroZ28.com!
__________________
1995 Black Trans Am M6
WS6 hood w/ ram air, Eibach Pro kit springs, KYB shocks and struts, Hotchkis LCA's, PHB, and subframes, 160* Powerstat, SLP OR Y pipe, Flowmaster catback, Granatelli MAF, air foil, MadZ28 tuning, LT4 KM, 2002 Polished WS6 Wheels with Nitto 555r DR's out back
Re: will about a half quart of oil over full hurt seals?
Quote:
Originally posted by TexasTechTA accidentally filled the oil up a little too much when i added a can of RESTORE. and it is abotu a half quart too full. Will this cause any leaks or damage any seals?
I'd be more worried about what you put in it, and not so much about the amount. I've never heard anything positive said about oil additives, especially ones with Teflon, which I'm assuming the 'Restore' uses.
__________________
Quote:
Originally Posted by HelloMrAnderson
This site is like my mother.
The new site is like a hot girl who gives me great sex.
Honestly, I wish there was a combination of the two.
ive used that stuff..dont worry about the level, in the 500 miles it suggest running itll be absorbed into the seals and restore cylinder pressure if needed...there are gonna be people that say it doesnt work but it does, ive seen it with my own eyes....
as most of you know SBC heads tend to make cloudy startups...my old sbc heads did that used this stuff never did it again....cylinder 3 and 8 were 18-20 psi below the other six and they werent consistant....i used a can of that stuff drove the 500 miles on a sat afternoon and tested the pressures again..not only were the to low cylinders up but it was a max 4 psi variance in all 8...that stuff does work.
yea I have been running it for about 2k miles justa little full. The oil pressure is great. anyway I am using mobil 1 syn with it. Any harm done?
__________________
If it were me I would drain it out and put the right amount of Mobil 1 in it without the Restore......at least drain it down to the proper full level. No harm done though.
__________________
Greg
95 Z28 conv M6 383 ci (SOLD)
Georgia FBody Association
used restore in my v6 and it stopped burning just that little bit of oil
only did it once or twice though in it and it still doesnt burn any
just did it in my z28 now too, same as you, with mobil 1 syn.
i would say don't worry about it imo
like said, the restore will probably be absorbed in a little bit
__________________
1992 Chevrolet Camaro RS 3.1L V6 A4- Metallic Green
1995 Chevrolet Camaro Z28 M6- Patriot Red Metallic
1995 Chevrolet Cavalier A4- Hawaiian Orchid
2004 Yamaha R6- Yamaha Blue/White
1988 Kawasaki ZX600- Custom paint- SOLD
I'm not going to comment on the additive but the overfill is an issue. It has nothing to do with seals with a slight overfill(1/2 quart or less) but with aeration. Even just a 1/2 qt extra can be whipped up by the crank and cause a loss in oil pressure. You may not see a problem if you drive the car easy on a daily basis but if high RPM is your thing it will be trouble.
__________________
1997camaro ss m6 #0068 sebring silver
Hotcam,slp headers & 2OTL,PCMForless,Moser 12 bolt(4.11)SLP clutch,Hurst B+,Kumho MX,ET Streets,Baer Brakes.
weight 3802,Best 60' 1.83,Best ET 12.61,Best MPH 110.73
Enemies are equal to.... wrath times the speed of fright squared. If you dont kill me.....I'm gonna have to kill you!
I ran Restore in my old saturn and in my moms mini van. I ran a compression test before/after on the saturn and the compression did become more stable.
The Saturn had 130k miles and with synthetics, i got 41 mpg on the highway.
