Whats the difference between Orange & Green antifreeze??? - CamaroZ28.Com Message Board
Reply
Thread Tools Search this Thread
Old 07-15-2004, 10:54 PM   #1
My car was originally filled with the orage antifreeze from GM, but sincei got it totalled, I had to refill the system. I was going to use regular Green antifreeze, like Dexron or whatever it is, and someone told me that i HAD to use the Orange stuff or it will mess it all up somehow, but never got into details. Just wondering what the difference was and how it would hurt the car if you had orange and went to regular dexron green antifreeze ... Thanks guys...
HardcoreRM125 is offline   Reply With Quote
Old 07-15-2004, 10:57 PM   #2
The taste Actually the orange is DexCool a GM long life product. The green is the normal stuff that has been around for ever. I have heard some bad things on dex. Lots of info here do a search.
944v8inDFW is offline   Reply With Quote
Old 07-15-2004, 11:28 PM   #3
I would go green better than dex.
Eliminator is offline   Reply With Quote
Old 07-15-2004, 11:30 PM   #4
I also heard that you must use it.....I might just be part of the urban legand though
smokindastangs is offline   Reply With Quote
Old 07-15-2004, 11:45 PM   #5
You can use one or the other, just not both at the same time. That's the problem. I believe the two different colors mix and create a sludge and you definately don't want that going through your engine. If you completely flush the system(block,radiator,& lines) you can use whichever color you want.
Jay-Roll is offline   Reply With Quote
Old 07-15-2004, 11:54 PM   #6
supposedly the orange dexcool works well and lasts a few years if its used right. it sludges up with a lot of air and especially if you mix it with the green stuff or so i have heard. the only way you can change over the orange to green is ifyou flush your system out thoroughly and drian it all out then add the green. im talking radiator, reservoir, block, and hearter core. if you do all that then u can change over. otherwise if u mix it could sludge up and cause major overheating problems. do a serach ull find some more ansewrs.
EaC95Z28 is offline   Reply With Quote
Old 07-16-2004, 08:21 PM   #7
Quote:
i had the same question and did a WHOLE lot of searching
basically, this is what i came up with
green-supposed to last 2 years
orange-supposed to last 5 years, most say it won't
if mixed, won't exactly create sludge but will reduce the life of the coolant
basically, i don't think it would really matter
just change it every 2 years or so and you'll be fine
this is just my opinion though, take it for what you will
unvc92camarors is offline   Reply With Quote
Old 07-16-2004, 08:28 PM   #8
n2oblkz
Guest
Posts: n/a
If your changing over, you might want to try the Evans coolant, from what I understand, it is supposed to be very good.
Old 07-16-2004, 08:54 PM   #9
n2ceptor's Avatar
n2ceptor is offline   Reply With Quote
Old 07-16-2004, 09:41 PM   #10
orange=
green=
And I'm talking from experience.
30thannZ28 is offline   Reply With Quote
Old 07-17-2004, 01:09 AM   #11
Used Dexcool after my motor rebuild and it does just fine.
Loadre is offline   Reply With Quote
Reply
Thread Thread Starter Forum Replies Last Post
New Here But I Need Help pimpen1024 General 1967-2002 F-Body Tech 12 08-19-2015 09:36 PM
Just got a nice 97 30th Ann Z28-whoohoo! 30th Anniv Z28 New Member Introduction 3 08-01-2015 11:39 AM
Hot weather issue Xiantyl LT1 Based Engine Tech 18 07-21-2015 06:42 AM
Proform aluminum 1.6 3/8 SA rockers JCSWS6 Parts For Sale 0 07-19-2015 07:47 PM
Cam for 93 LT1 Z28amustangklr LT1 Based Engine Tech 0 07-18-2015 12:05 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
