what would happen if you install the fuel filter the wrong way?
Old 02-13-2005, 10:55 PM
whataretheodds's Avatar
just curious what would happen if you would install a fuel filter the wrong way? my brothers 1995 camaro fuel filter has 2 nipples at the end and i guesss the person stripped the nut before and just used fuel hose and a fuel filer with the 2 nipples sticking out so if he would install the fuel filter the wrong what would happen? or would it matter?
whataretheodds is offline
Old 02-13-2005, 11:24 PM
Re: what would happen if you install the fuel filter the wrong way?
I was going to say you cannot install it wrong, but you have a special situation. I hope the rubber hose holds-not a great idea.
It probably would not flow as well as in the proper direction. Most filters have an arrow or some printing on them indicating flow.
shoebox is offline
Old 02-14-2005, 12:22 AM
MaxLean's Avatar
Acutally flow would roughly be the same but filtering capacity would be greatly reduced.
MaxLean is offline
Old 02-14-2005, 10:24 AM
JohnD's Avatar
Typically in paper filters, the flow is from outside to in so that the paper is pushed in and strengthened by the pleats. In ther reverse direction, is is entirely possible that the element might fail by being sresssed inside to out.
JohnD is offline
PCLZ28
12-24-2015 05:19 PM
Alex Barnes
01-24-2015 10:21 PM
Deadbolt24
01-19-2015 01:29 PM
30thZ4C
12-26-2014 05:09 PM
supercharged94Z28
02-24-2003 10:22 PM
Quick Reply: what would happen if you install the fuel filter the wrong way?
