What would cause having a Gas Gauge needle stuck at full?
Old 11-29-2004, 05:19 PM
crAzy95z28's Avatar
i took out the assembly, tried messing with all the wiring, and that didnt work!!!
any other clues?
crAzy95z28 is offline
Old 11-29-2004, 05:20 PM
TobyZ28's Avatar
Re: What would cause having a Gas Gauge needle stuck at full?
Is your gas tank full....?
TobyZ28 is offline
Old 11-29-2004, 05:41 PM
My94T/A's Avatar
My 94 has the same problem. Took it to the dealership and they said the Fuel sending unit is broken so I picked one up from this site. U just have to look out for Parts for sale and you might score a deal.
My94T/A is offline
Old 11-29-2004, 05:56 PM
crAzy95z28's Avatar
pics of the sending unit?
Old 11-29-2004, 08:41 PM
My94T/A's Avatar
Sorry couldn't get a pic of the sending unit....check out this site
https://www.rockauto.com/applet3.html if u email them...they might sent you pic....
My94T/A is offline
Old 11-29-2004, 08:49 PM
crAzy95z28's Avatar
300$$$$$$$$$$$$$
Old 11-29-2004, 09:49 PM
Birdman7389's Avatar
Time to call Jason Cromer.....
Birdman7389 is offline
Old 11-30-2004, 10:51 AM
93ZM6Tally's Avatar
Don't have pic's of the sending unit but it's the complete assembly that your fuel pump, (inside the tank), mounts to, including the lines that you see coming out of the top of the fuel tank. FWIW I picked up a complete unit including fuel pump for $50.00 at a local salvage yard. I changed the fuel pump, but the wiring, level sensor, float and everything else are working fine.
And BTW and open ground connection will cause your fuel guage to read Full, usually pegged past the "Full" mark. Check your connectors which are underneath the car near the rear axle on the drivers side, basically up in the "hump" that your rear seat back sits on.
93ZM6Tally is offline
Old 11-30-2004, 11:00 AM
Tom Piper's Avatar
Last summer, there was some high-sulfur gas (I think it was Shell) got out to some gas stations that caused many sending units to "lock up."
Shell had to repair several for customers.
Tom Piper
Tom Piper is offline
Old 11-30-2004, 11:30 AM
Banned FOR SCAMMING - Nick[William] Dascal - (516) 931-0586
OnefstCamaroZ28's Avatar
yep its just a bad sensor, my mothers dodge caravan gets stuck at full for like 1/2 tank then it will drop right down to 1/2 instead of Full all the time, Very weird
OnefstCamaroZ28 is offline
Old 11-30-2004, 01:44 PM
crAzy95z28's Avatar
i might check the wires, cause it stays pegged at full, and everynow and then, it starts to drop to a bit above the half mark!!!
Old 11-30-2004, 04:07 PM
You can check the sensor by measuring the resistance as it moves from empty to full. Shoebox (as usual) has the resistance values on his Tech Pages website.
Injuneer is online now
Garcia5
07-07-2022 06:51 PM
99TransAmWS6
02-12-2015 07:23 PM
The Seer
Classic Engine Tech
11-26-2014 05:55 PM
blac94Z
11-24-2014 07:12 PM
simple
08-11-2002 11:56 AM
Quick Reply: What would cause having a Gas Gauge needle stuck at full?
