what size rings to run
Old 09-27-2004, 11:31 PM
92rslt1's Avatar
what are the sizes of a lt1 engines rings??
92rslt1 is offline
Old 09-28-2004, 07:45 PM
5.7LT1Formula's Avatar
Re: what size rings to run
ring size will have to do with Bore and size of your piston..if you have a .030 bore..you'll need a .030 piston w/ standard rings...on some pistions you may need to file fit your rings (which is a pain..i had a machine shop do mine)
5.7LT1Formula is offline
Old 09-28-2004, 07:55 PM
arnie's Avatar
I trust you are referring to ring widths (or thickness). AFAIK, the sizes are 2 mm., 1.5 mm, and the oil ring is 3.8 mm.
arnie is offline
Old 09-28-2004, 08:55 PM
1racerdude's Avatar
If you get aftermarket pistons get 1/16--1/16--3/16 they are the most common and cheapest.
1racerdude is offline
Old 09-28-2004, 10:19 PM
92rslt1's Avatar
are these rings hard to find in mm sizes?
92rslt1 is offline
Old 09-28-2004, 10:29 PM
1racerdude's Avatar
Shouldn't be.
HectorM52
07-30-2017 11:46 AM
10-31-2016 11:09 AM
Feffman
10-09-2015 05:42 AM
1963SS
02-06-2015 10:05 AM
1775.Z28
01-11-2015 10:51 AM
Quick Reply: what size rings to run
