What is this raddling noise?
I need your help
Recently my car has been making this raddling metal on metal type of noise...kind of like a chattering.
At first it seemed pretty harmonious with the engine...when I revved up it would get louder and idling its pretty soft, but after driving today I could be wrong.
Today when I got to class, I popped hte hood to see where it was coming from, and at first I thought it was the alternator just being noisy and gay, but after listening more closely it sounded like it was coming dead center from the engine...more towards the front
As I got back to my car to shut it off I noticed the temperature up to about 250
It usually never gets above 180 as my trip to school is about 2 miles.
Up in my top list of fears next to sharks and getting my ***** cut off, is a spun bearing, so I'm praying to god thats not it.
The car drives strong from what I can tell.
Thanks for all your help!
EDIT: Screw it, I made room.
I had that same sound and thought it was the alternator. It wasn't, it turned out to be dirty pullies. Yes, dirty pullies will make the the belt slip just a bit and cause that noise.. I checked the tech bulletins on AllData when it happened and found that a dirty or misaligned belt causes a 'chirping' like rattleing sound. I tried just replacing the belt at first but the noise soon returned. I took it off and cleaned all the pullies with brake drum cleaner. I put it back together and haven't had the 'chirps' since.
Take your belt off and see if the noise goes away. If it does try a new belt and cleaning the pullies. If the noise doesn't go away with the belt off then start looking elsewhere.
Have you physically looked at the waterpump? Specifically the weephole to see if it is leaking? When a w/p starts making noise usually it'll start leaking as well. Have you changed the timing chain? It may be worht while to take the timing cover off to make sure the cam sproket and w/p gears are ok.
and my jack broke and my hydraulic is back home so I cant get under the car at the moment to get a better look
The water pump looks alright from the outide...and I'm not sure what the weephole is?
Haven't touched the timing chain or cam sprokets
but still would any of that cause the temperature rise?
It kind of sounds like its coming from the the throttle body
Other problems with the car that may or may not be related:
the idle will be off sometimes...sometimes idling at 1100-1200 for long periods of time.
Also stompin on the gas at low rpms in any gear...say 2nd at 2000 rpms causes the car to stumble pretty bad throughout the rpm range, kind of surging I guess
And so far the coolant level is staying constant.
autoxr166
09-25-2015 04:21 PM
colts0455
13
08-07-2015 09:15 PM
