What push rod for hot cam lt1. - CamaroZ28.Com Message Board
Reply
Thread Tools Search this Thread
Old 10-04-2010, 04:09 PM   #1
I have a 1997 trans am with the lt4 hot cam kit and 1.6SA comp promag rockers. I am running stock push rods now, but I have a miss on cylinder 7 and slightly on 8. I changed and rehanged all ignition and fuel parts, I even ran a compression/leak down test. Every thing checked out, but I notice that the valve train has some slight ticking to it; especially at higher rpms. I think I may have a bent pushrod and I plain on checking them tomorrow. If I do find bent push rods what push rods should I buy for this set up? Or are the stock push rods no good for this set up and should be changed anyway?
henryz28 is offline   Reply With Quote
Old 10-04-2010, 04:16 PM   #2
the cam is made to work with stock pushrods.....Maybe look into hardened ones if you need to replace them, but a "tick" would probably be a lifter instead...in which case get a set of LS7 lifters and be done....
crash4cyl is offline   Reply With Quote
Old 10-04-2010, 04:25 PM   #3
LS7 lifters were installed with the cam.
Old 10-05-2010, 11:11 AM   #4
if you have to or just want to get new pushrods, i went with the trickflow pushrods. they are fairly inexpensive thru summit racing. if i remember i used stock length with my cam. tfs-21407200 was the part number. good luck
PHINES LT1 is offline   Reply With Quote
Old 10-05-2010, 07:53 PM   #5
I installed the crane cc305 (similar to hot cam), with lt4 heads. I noticed the new gm lifters I used (12499225, part num for 16 lifters) had a push rod seat that was more shallow than the stock lifters being replaced. Using a push rod length checker, I measured a length of 6.95 inches, that would be best for my resulting geometry. I believe the stock push rod length is 7.2 inches. I used scorpion 1.6 roller rockers. It would be a good idea to measure your own configuration to be sure. A pushrod that is too short or to long will cause unnessessary side loads on your valves causing premature wear. If you plan to increase your red line, (usually done with hot cam and roller rockers), it would also be a good idea to use hardened rods. This reduces the spring effect (bad) of push rods which may cause hammering (more excessive wear on valve train).
this page had some good info on push rods
http://scorpionperformance.com/newsi...q/?p=127#faq41
hope this helps good luck
cornelius107 is offline   Reply With Quote
Reply
Thread Thread Starter Forum Replies Last Post
LT1 Perf Parts: Ported heads, rockers, BBK TB etc... oldschool Parts For Sale 16 02-09-2016 10:21 PM
Lt1 parts- msd opti, crane springs, ect nikolt1 Parts For Sale 2 02-27-2015 10:10 PM
wanting to upgrade ModdedNerd LT1 Based Engine Tech 6 02-05-2015 05:37 AM
what all interchanges between the iron and al heads Brandon Wittmer General 1967-2002 F-Body Tech 0 12-07-2014 01:15 PM
Poor gas mileage...?? The Seer Classic Engine Tech 2 11-26-2014 06:55 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
