what happen when the radiator cap gone bad??
can a bad radiator cap causes the temp. to rise up slowly?? just wondering if that's the cause of my rising temp when i turn my AC on....
thanks
thanks
It's fairly normal for the engine temp to rise a little with the A/C on due to the load.
If your cap is bad, that can also cause overheating. If your cap is original, it wouldn't hurt to change it out, they're pretty cheap.
If the cap is not keeping adequate pressure on the coolant, its going to let coolant into the overflow tank. This one reason you should replace a faulty coolant level sensor and not just unplug it. If you keep topping coolant off and it never levels off and you know its not a headgasket or leak, its likely the cap!
Ryan
Ryan
Originally posted by toby360
AC takes my car temps down. Turns the fans on sooner in traffic... keeps temp around the 1/4 mark.
what do i have to do???
maybe i need to reprogram my fans not to shut off untill i reached the speed of 45 MPH
Originally posted by gb95zconv
Im with Brent on this one....my temp goes up 10-20* when the ac is on...now befor I started using the 160* tstat and reprogramed the fans the reverse was true.
My temp goes up too when the A/C is on. And when it's not, my car runs cool.
I checked with a logger, and you can see that the A/C adds load onto the engine. Just at idle it'll go from ~30kpa to about 38-39kpa. That will make the engine run hotter, no doubt, even if the fans come on.
My radiator cap lost complete pressure within 5 seconds on the cap tester and it DID CAUSE A HIGHER TEMPERATURE!! I put on a new cap and like everyone else now with 160 t-stat, watter wetter, new radiator and waterpump, I usually do not pass the 185 mark unless I turn the car off, back on, then off again, then back on. I wish i had replaced the cap before I did all that stuff though, andyes the temp should be slightly higher with the ac on, cause it will send heat into the engine bay.
