What is this air valve called/used for
Old 07-23-2014, 11:57 AM
4586's Avatar
Putting a 95 LT1 engine in a streetrod and stripping it down to bare essentials (have benchtop cables to program the ecm).
What is this air valves' function. Located on passenger side between injectors, 2 wire plug, 2 vacuum lines.
4586 is offline
Old 07-23-2014, 12:22 PM
Re: What is this air valve called/used for
EVAP purge solenoid. When it opens, engine vacuum from the passenger side of the throttle body pulls the hydrocarbon vapor out of the carbon canister in the driver rear fender:
http://shbox.com/1/evap_sol.jpg
Injuneer is offline
Old 07-23-2014, 01:10 PM
4586's Avatar
Injuneer
Thanks ..you always come to the rescue!
Ed
4586 is offline
HectorM52
07-30-2017 11:46 AM
RUENUF
05-25-2016 08:10 PM
RUENUF
03-13-2016 03:39 PM
oldschool
02-09-2016 09:21 PM
95chwagon
01-13-2015 09:19 PM
Quick Reply: What is this air valve called/used for
