What is this?
What is this?
Can some one tell me where this plug goes? Its mixed in with the starter wires and i cant find any where to plug it in. I just got done installing headers and put the starter and dip stick in last. found that wire when installing the starter
Delete an Image - Imgur
Re: What is this?
Right side O2 sensor. Shoebox has a "clickable" photo of a 95 wiring harness, and it clearly shows that connector in the same bundle as the starter, PCM ground, and knock sensor wires.
Great resource, best place to look for basic info like this.
Re: What is this?
The factory Y-pipe had an O2 sensor a few inches down from the connection to the passenger side exhaust manifold. You have to take the O2 sensor out of the Y-pipe, and screw it into the bung on your new Y-pipe or the header collector (depending on whether you installed "shorties" or long tubes), just like you had to take the driver side sensor out of the base of the exhaust manifold, and relocate it to your headers collectors or the Y-pipe.
Looks sort of like this on my Formula with mid-length headers:
