Water pumps leak oil?
Re: Water pumps leak oil?
..my bearing in my waterpump drive shaft(inside waterpump) went out and was shot..i could see where it leaked on my opti..but never runied it..when your water pump leaks..it is the bearing that is the main cause..then the seal goes which you will see coolant and a little bit of oil leaking.
When I replaced my water pump, after it went bad, it began to leak oil. I haven't fixed it yet but my dad and I got seals/o-rings for the splined water pump drive and for behind the opti, to see if that fixes it.
I've had no problem with my opti, and it has seen a lot of water/coolant/oil over it.
Magenta_Hearts
03-29-2017 08:54 PM
