water pump drive gear
Old 01-30-2016, 10:14 AM
TA Dreaming's Avatar
Does anyone know if the water pump drive gear is still available new? I can't seem to find any info on it other than used ones on Ebay. Is it called something else? I even searched GM Part Direct without luck.
I'm looking into this because I'm going to be building a 383 soon. I intend to upgrade to an LT4 or better timing set. Thought it would be best to change out the water pump drive gear while I'm in there instead of reusing the old one.
TA Dreaming is offline
Old 01-30-2016, 11:05 AM
RUDEDOG's Avatar
Re: water pump drive gear
You are better off going with the GM Extreme Timing Chain set. It comes with a new water pump drive gear.
RUDEDOG is offline
Old 01-30-2016, 11:53 AM
bw_hunter's Avatar
Another option is an electric water pump and the timing chain set of your choice. Note, a lot of people are negative on the electric setup because it does or flow as much at maximum rpm.do a search and you'll see what there is to find.
I use an electric pump and switched to a Cloyes double roller chain...
bw_hunter is offline
Old 01-30-2016, 05:10 PM
Thanks. I'm glad to hear that. I didn't think it would come with the timing set. I appreciate the reply.
Old 01-30-2016, 06:15 PM
bw_hunter's Avatar
The LT1/LT4/extreme cam gear have the water pump gear on the back. The shaft that sticks through the cover is driven from that. It does not come in the timing set..
Old 01-30-2016, 09:36 PM
Sad to see that the water pump drive gear has been discontinued.
shoebox is offline
Old 01-31-2016, 09:13 PM
any idea on what my options are for changing out the drive shaft as well? I think I can reuse mine but in case I can't it would be good to have a back up.
I'm beginning to think I should just hold on to this extra 95 LT1 I have. Seems some of these parts are getting harder and harder to find.
Old 02-01-2016, 03:55 PM
timnfxr's Avatar
Summit carries it, although a little pricey IMO.
Chevrolet Performance LT1 Water Pump Driveshafts 10128334 - Free Shipping on Orders Over $99 at Summit Racing
timnfxr is offline
Old 02-01-2016, 06:22 PM
Fatdog2's Avatar
Suburban chevrolet on Oregon shows this # 10128334 for $39.21
Fatdog2 is offline
Old 02-01-2016, 07:46 PM
bw_hunter's Avatar
I show tat part number as the coupler, not the driveshaft....
Old 02-01-2016, 07:57 PM
The Summit link only shows the coupler. Bend over.......
$54..........
Injuneer is offline
Old 02-01-2016, 09:19 PM
Thanks guys. Yes, I'm referring to the drive that sticks out of the front cover that the couple goes onto. I found a listing for the bearing on an el camino website but the shaft itself I'm not finding anywhere. Can the sealing surface be polished if necessary on the shaft or will that make it too small?
Old 02-01-2016, 10:10 PM
There's an Engine Builder magazine article on "Rebuilding The Chevrolet LT1 Engine" and it includes a close-up photo of the bearing cage/retainer plate/gear/shaft assembly - which as far as I know is all one assembly - , with the caption "Make sure..... that the seal surface isn't grooved before reusing it." Do a search and take a look at the picture. Reducing the diameter of the sealing surface would seem to be risky, given the difficulty of installing the seal correctly.
The "How To Rebuild Small-Block Chevy LT1/LT4 Engines" soft cover book also shows the assembly as a complete unit.
If you found the bearing, that should be the complete unit. Hopefully the old El Camino website isn't showing something from the Gen 1 version of the LT-1.
Injuneer is offline
Old 02-02-2016, 06:09 AM
They are talking about the bearing itself being sourced from a bearing supplier
LT1 Water pump Drive Bearing part number - El Camino Central Forum : Chevrolet El Camino Forums
I was hoping to find the complete assembly but shoebox says it's discontinued. If someone knows what the part number was, I can always do a search that way, too. I'll be changing the timing set to the extreme set which will give me a new gear but I still have to consider the shaft and bearing.
Thanks Fred
Old 02-02-2016, 08:32 AM
P/n 10219554.
shoebox is offline
Quick Reply: water pump drive gear
