want to upgrade
Old 01-27-2015, 09:41 PM
edxiel's Avatar
want to upgrade
Hey i have a 1995 z28 automatic its stock how should i go about upgrading it and keeping it reliable
edxiel is offline
Old 01-28-2015, 01:06 AM
Fatdog2's Avatar
Re: want to upgrade
Depends on the budget.
Throttle body coolant bypass.Cheap.I haven't done this yet,and I'm so ashamed,but will get around to it.Good for 6-7 ponies.
Cat back system.About ten hp I think
Cold air system.I would do this first.About 10 hp I think
Decent tires.Hard to find ones for the 16 inch,but I'm happy with my coopers.
Zeon RS3-A.Some vette folks run them.They are predictable and hold pretty well.I used to run firestone sz50's, but I like these better.
Why don't you post a signature it's real easy.
NGk spark plugs.Used to run the non plats, but got tired replacing them all the time so I run the plats.Super happy here.Other members like the iradium plugs.
The coil wire is the weak link in the chain,so I would replace that often.
Hope this helps.Beer time.
Fatdog2 is offline
Old 01-28-2015, 04:17 PM
Chimera96's Avatar
Re: want to upgrade
If smog is not a problem, get long tube headers.
CAT back exhaust
Cold air intake system
PCM tune (use a 160 T stat)
new, better valve springs
1:6 RR
3:73's
2600 RPM stall TC
Chimera96 is offline
Old 01-29-2015, 08:41 AM
maybe2fast's Avatar
Re: want to upgrade
PCM tune
CAI
Headers this will be a huge boost
maybe2fast is offline
Old 01-30-2015, 12:12 AM
edxiel's Avatar
Re: want to upgrade
Thanks for all the input,luckily i dont need to worry about smogs but i do about money haha i have 1500$ to work with what should i do first and any specific brands i should go with
edxiel is offline
Old 01-30-2015, 12:17 AM
edxiel's Avatar
Re: want to upgrade
alright intake catback bypass got it ,might sound stupid asking this but what do you mean by post signature
edxiel is offline
Old 01-30-2015, 12:31 AM
Fatdog2's Avatar
Re: want to upgrade
Easy ,just go up to UserCP left hand corner of the page and click on it and you can describe you car like stick or auto trans,any mods done,hard top or convert.Then every time you post something,it will show up at the bottom of your message,so folks can better help out.Hope this helps.
Fatdog2 is offline
Old 01-30-2015, 08:00 AM
maybe2fast's Avatar
Re: want to upgrade
heres your list:
LLP stainless headers 1 3/4 (mention LS1tech for discount)
Pacesetter y-pipe
PCMforLess tune
Cold Air Intake of your choice
should be under budget and a huge performance bump
13qtr
10-28-2016 08:11 PM
Mikes 1994 z28
10-10-2015 07:55 AM
MDZ28
11
09-24-2015 09:15 AM
Tarizza
3rd Gen / L98 Engine Tech
09-20-2015 03:26 PM
97SSdude
08-21-2015 09:36 AM
Quick Reply: want to upgrade
