wait a minute....two bleed valves???
Ok guys, i admit that i don't know a whole lot about cars. I have some knowledge with mine though, just from issues that have sprung up over the past five years that i've owned the car. ('97 z28 automatic). I know to bleed the coolant system after flushing and refilling but i only see one bleed valve (easily accessible on the piece which sits bolts directly atop the thermostat). Where is the other one?? this was mentioned in a previous thread. Also...please educate me on thermostats. I have a 180 deg. one. Are there different ones and which is best??
Thanks in advance
Thanks in advance
Re: wait a minute....two bleed valves???
The other one is to the left of the IAT in the pic:
http://shbox.com/1/iat.jpg
The other one is on the top pass. side in one of the hoses coming out of the water pump. They put a metal section in the hose and that is where its mounted in.
yes there are two, one on the thermosat area, the other is just a few inches on a smaller hose that run the steam line for the TB. As for the 180 thermosat it will be fine. The lower you go will not do anything unless you you program the car with a lower t-sat.
Originally Posted by Z95m6
Thats false, my car will idle all day long just barely over the 160 mark on the gauge on stock fan settings as long as its not 100degrees out.
Yeah the thing that looks like an AC line is actually the Inlet water line. This is where the other bleeder valve is.
They do make other thermostats. I have 160 degree thermostat. It stays right around 160 all day. In traffic it will rise, but as soon as i start moving it rapidly cools down. I do have a cowl hood though. You should bypass your throttle body too. Since yours is a 97 you wont even need a kit.
Originally Posted by texas_z28_guy30
thanks, it was right in front of me all along!
