vibration throughout the car
Old 01-28-2015, 06:10 PM
karnykamaro's Avatar
95 z28 Lt 1 m6
One day drive fine started next day and there was a vibration throughout the car when I start it no problems starting just feels like a knock but when I stick my head under the hood no noises except for a slight tap on driver side front of valve covers nothing major it seems but the vibration is in time with the exhaust sound that I have. The more gas I give her the more predominate the sound. When driving it doesn't quiet down the vibration sound feeling whatever u wanna call it is more predominate when pulling up a hill or putting the car under more strain please help me out !!!!!
karnykamaro is offline
Old 01-28-2015, 06:32 PM
moparman's Avatar
Re: vibration throughout the car
U joint causing the drive shaft to vibrate?
moparman is offline
Old 01-28-2015, 08:57 PM
To be clear - the vibration is in synch with/proportional to engine RPM and exists whether the vehicle is stationery or moving???
Injuneer is online now
Old 01-29-2015, 04:14 AM
Yes
Old 01-29-2015, 08:38 AM
maybe2fast's Avatar
Do you have headers? Y-pipe hitting the floor due to a bad motor or trans mount...ask me from experience
maybe2fast is offline
Old 01-29-2015, 03:05 PM
No pipe is up I drove it today I'm thinking maybe a miss almost like a cylinder is down or something
Old 01-29-2015, 03:06 PM
I check wires today at work they seem good its too cold with no garage to work in
Old 01-29-2015, 04:35 PM
Best time to check the plug wires is in the dark, after LIGHTLY misting them with water. Look for arcing with the engine running. You aren't going to be able to tell much about the condition of the wire just by looking at them, unless they've been clearly burned on headers, rubbed through by the serpentine belt, or just generally in rotten condition.
Old 01-31-2015, 12:20 PM
Wires are new to describe it better u can say there's a harder pop to the exhaust sound then before and that's what I believe I'm feeling. Replaced wires opti water pump and I believe plugs but can't remember back In october
Old 01-31-2015, 12:48 PM
Sure sounds like a misfire - pop in the exhaust, more predominate when pulling up a hill or placing the engine under load. Make sure a wire didn't come off the plug, you don't have corrosion on the wire towers on the Opti, make sure a plug was not loose and popped out, etc.
Old 02-01-2015, 04:38 AM
Will check into that as well today while at burger king I noticed the slight valve tap getting louder would that have anything to do with it
Old 02-01-2015, 09:20 AM
Sure. In incorrectly adjusted valve can cause misfires.
Old 02-01-2015, 08:30 PM
So what's my easiest and cheapest course of action cause I think its that the more I think of it AND what would my course of action be to fix and upgrade the problem part everything is pretty much stock
Old 02-02-2015, 12:53 AM
Fatdog2's Avatar
What condition are your plug wires?
Fatdog2 is offline
Old 02-02-2015, 09:17 AM
Brand new this past October have maybe 2000 miles on them at best
Quick Reply: vibration throughout the car
