Very Important ? About Timing
I have gotten two different answers from two different spec books. On a 97' V8 Camaro, there on holes on the camshaft sprocket, and the driveshaft, do they both go at a 12 o'clock setting, or are they at 12 and 6 o clock so that they are touching each other.
Re: Very Important ? About Timing
Originally Posted by CColtManM
I have gotten two different answers from two different spec books. On a 97' V8 Camaro, there on holes on the camshaft sprocket, and the CRANKSHAFT, do they both go at a 12 o'clock setting, or are they at 12 and 6 o clock so that they are touching each other.
The two dots need to be facing each other the Cam gear will have it at 6 o clock and the crank gear will have it at 12 o clock. You should really have a degree wheel kit to make sure that the camshaft is installed at the correct spot.
Bret
I read a book that they both had to be at 12. So that is wrong?
I understand your confusion, as this used to confuse me. If you install both sprockets with the dots at 12 oclock, you will be at TDC of the compression stroke on the number 6 cylinder. If you install the dots at six and twelve(dot on top of crank gear and bottom of cam ger), you will be at TDC of the compression stroke on the number 1 cylinder. Either way is right. Since the cam turns at one-half crank speed, one turn of the crank will move the cam dot from the six to twelve o'clock positions. When installing a timing chain it is usually easiest to line the dots up at six and twelve oclock, and then rotate the crankshaft one turn so you are at TDC on #1. This is where you want everything when you install your distributor/opti. On traditional SBC's many people, myself included, have installed the chain dot to dot and forgotten to roll the engine over to #1 TDC. This results in a distributor that is 180 degrees off, and sometimes a carburetor fire from backfiring. I hope this helps.
Don't forget that for every revolution of the cam, you get two revolutions of the crank. So, line the dots up so they "are touching". Turn the crank 360 degs with the chain on and both dots will be at 12 o'clock.
Thanks izzy. I am working on it with my best friend, so far so good. We are done with the tear down, just putting it together. We did both at 12 o clock, i hope that is right. But now you guys are confusing me?
Originally Posted by LT4orbust
That is right, some books say one way some the other,it'll only affect the way you install the dist. but make sure they are lined up with a straight edge first
Originally Posted by Kreinmc
There is only 1 way to install an opti!
