Underdrive Pulley
Old 09-23-2004, 04:02 PM
badasschevy625's Avatar
Underdrive Pulley
does anyone know a good underive pulley system that doesnt mess with anything i have heard some dont let your battery charge and some make it run to hot let me know which ones the best thanks?
badasschevy625 is offline
Old 09-23-2004, 05:00 PM
BiGGinZ's Avatar
Re: Underdrive Pulley
This is what I have. Just read the little bit of info it gives.
http://www.jegs.com/cgi-bin/ncommerc...16&prmenbr=361
BiGGinZ is offline
Old 09-23-2004, 08:58 PM
Mtrhds94Z's Avatar
LT1's won't run hotter due to water pump not belt driven..
Battery voltage suffers tho, yes.. I don't find it a real prob with mine, I pop it into neutral if sitting long at lights etc..
Mtrhds94Z is offline
Old 09-23-2004, 09:54 PM
MarkyMark's Avatar
I'm a strong believer in the ASP replacement underdrive pulley. I have the alternator underdrive one also, but voltage gets kinda low....so I would just get the crank one only and not the alternator one if you are worried about low voltage and charging.
MarkyMark is offline
Old 09-24-2004, 06:37 AM
jeremyferguson's Avatar
Was there any noticeable difference installing it? I know the question has been asked a million times, I'm just wondering if YOU thought it was worth it. I'm just wanting to get the last couple bolt-ons done before I go internal
jeremyferguson is offline
Old 09-24-2004, 08:02 AM
BiGGinZ's Avatar
For the price to me it is worth it. Couldn't tell much of a gain but I could feel the throttle response got better. Here is a dyno that someone did
http://ws6.com/mod-2.htm
A 5 torque peak and 5 hp and 5tq ave. gain under the curve is enough for me to dish out $100 for it. It will not hurt your performance it could only help.
BiGGinZ is offline
Old 09-24-2004, 09:20 AM
trans9_5am's Avatar
I also feel the ASP has a nice underdrive pulley/damper. That would be the way to go if i were you.
Brandon
trans9_5am is offline
Old 09-24-2004, 09:36 AM
ishz28's Avatar
I just took mine off after five years and didn't really notice anything other than the battery stays at 13 Volts now.
ishz28 is offline
Old 09-24-2004, 10:12 AM
WS Sick's Avatar
I had a belt sqeal every time the car shifted under WOT I changed the belt and everything and it never went away I even replaced the tensioner !!!
I added the ASP 34 % underdrive pulley and it gave a little power but it did away with the belt squeal !!! (figure that one out). My charging is effected a little but it still hardly ever goes below the 13 on the gauge, the largest noticeable difference is that when everythings going and youhave your headlights on when at a stop they dim slightly.
WS Sick is offline
Old 09-24-2004, 10:29 AM
trans9_5am's Avatar
If everyone is so worried about charging, get an overdrive pulley for the alt. Then both your goals are fulfilled. Its as simple as that.
Brandon
Old 09-24-2004, 10:52 AM
orbitalshock2k's Avatar
UDPs are good stuff, I had one on my old car. Go 4 it
orbitalshock2k is offline
Old 09-24-2004, 10:56 AM
SS MPSTR's Avatar
I have a March UD crank pulley for sale if anyone is interested.
SS MPSTR is offline
Old 09-24-2004, 11:38 AM
aaron_depue's Avatar
I want to but an UDP set up to. I am also curious. I had my mine set on a March power and amp pulley set up. It has both pulleys. Has anybody heard the pros and cons of this set up? Goes for about 115$ and you shouldnt have tho worry about the volts dropping low because, an alt. pulley is included. Feedback would be greatly appreciated
aaron_depue is offline
AviatorDave
12-19-2016 06:35 PM
RUENUF
03-13-2016 03:37 PM
sleeperZ96BT
09-09-2015 08:28 AM
Slayer
08-17-2015 03:55 PM
Rde Bandit
03-21-2015 10:17 PM
Quick Reply: Underdrive Pulley
