Tired of replacing fuel pumps
Old 01-22-2015, 12:37 PM
RiverMutant96's Avatar
My 3rd fuel pump is now DOA. Does anyone know of a brand or model pump that will live longer than a year. Sick of dropping the rear end to get the tank out of my convertible. Not willing to buy a dealer pump again.
Rob.
RiverMutant96 is offline
Old 01-22-2015, 01:18 PM
timnfxr's Avatar
Re: Tired of replacing fuel pumps
ACDELCO # FLS1077 or DELPHI # HP10036. Both available at Rock Auto at a good price. I've used the Delphi on mine and son's 95s. His was replaced 3+ years ago, and my original (220k+ miles) was replace approx. 1.5 years ago.
timnfxr is offline
Old 01-23-2015, 07:49 AM
raroz28's Avatar
I bought a walbro. Died after a month and left me stranded. I cut the hole in my hatch so I was able to replace it on the side of the road with a replacement.
That one went bad after about a year.
I then bought a used walbro from a forum member and it has lasted me for the last 7 years.
My point is - I wouldn't buy a walbro.
If you are going through pumps that often, be sure that your fuel system is clean and that there are no obstructions.
raroz28 is offline
Old 01-23-2015, 09:08 AM
Check the voltage at the harness connector over the rear axle. Needs to be at least 12V.
http://shbox.com/1/fuel_pump_connector.jpg
Injuneer is offline
Old 01-23-2015, 10:02 AM
Thanks Tim, but I think I'm done with that AC-Delco model. It may be bad luck on my part, but they are made in China. Maybe the Delphi would be a better choice.
I certainly will check voltage and if there is any fuel system contamination. Really appreciate the info.
Rob.
Old 01-23-2015, 10:39 AM
In addition to voltage, when you pull the old pumps out, it there evidence of sludge or rust on the sock? Do you frequently run the tank level low? Are you reusing the bucket with the new pumps? Does your local fuel contain high ethanol levels?
Injuneer is offline
Old 01-23-2015, 11:24 AM
Actually Fred the pumps look like new when I pull them out. Other than the plastic looking a little yellowed. The Delco pumps that I have purchased from the dealer come complete, so I never re-use anything but the cover ring. I have never run ethanol in any of my vehicles. Lucky to have real gasoline where I live. I do not run my car in winter, so it always sits with a full tank. I thought that could be the problem.(Sitting for long periods?)
Old 01-24-2015, 01:07 AM
Fatdog2's Avatar
I've read where the hot rod folks use a gas stabilizer for storing long periods of time in their tanks.Hope this helps.
Fatdog2 is offline
Old 01-24-2015, 05:06 PM
Chimera96's Avatar
River..
as Fred notes, confirm your voltage is 12v+ at the connector at tank. Lower voltage will kill any pump
Chimera96 is offline
Old 01-24-2015, 07:34 PM
I will check the voltage tomorrow as I will be working in my shop. I did buy a new relay last year just to have 1 in stock. Maybe I'll get lucky!
Rob
Old 01-26-2015, 02:44 PM
maybe2fast's Avatar
I used the racetronics "hot wire kit and their pump (walbro)"
http://www.racetronix.biz/customkiti...c=RFPK-003&eq=
maybe2fast is offline
Old 01-28-2015, 10:39 AM
Well my voltage looks good, so now I have to decide which pump to try next. The Racetronix looks like it may hold up?
Old 01-28-2015, 01:34 PM
maybe2fast's Avatar
Get the hot wire kit along with it!
Old 01-30-2015, 08:19 AM
maybe2fast's Avatar
(New) Racetronix LT1 F-Body Fuel Pump Power Harness - LS1TECH
Old 01-30-2015, 09:21 AM
Thanks 2Fast. Already have one on the way with new pump!
BADAZZ_Z
Parts Wanted
03-05-2019 12:55 AM
10-31-2016 11:09 AM
Jessie4tin
01-07-2015 08:53 AM
ANDYZ28
12-29-2014 09:13 PM
blac94Z
11-24-2014 07:12 PM
Quick Reply: Tired of replacing fuel pumps
