Tip for stuck ground cable?
#16
Re: Tip for stuck ground cable?
Can anybody confirm whether the small black and white wire from the PCM to the block can cause a slow crank when warm? That is one ground that I did not clean up. I'm wondering if this could be a culprit.
#17
as far as ground cables go I just bought a 1996 z 28 and looking around in engine compartment I found a ground cable on the drivers fender that was just hanging any idea what it was supposed to be grounded to thanks richard
#18
If its the braided ground strap, it is bolted to the subframe. The other end is connected to the stud the holds the coil/ICM to the head. Is this the ground you referring to?
#19
Don't think so. There are folks that have mistakenly left this disconnected before.
#20
Then I imagine my battery is no good from the years of driving with the old alternator. It was only putting out 13 volts and anytime I get that battery tested it just barely passes - CCA's are well below what's on the battery label.
sleeperZ96BT
09-09-2015 08:28 AM
08-24-2015 06:41 AM
detroitmuscle
07-31-2015 04:21 AM
