Tip for stuck ground cable?
Old 08-05-2014, 07:42 PM
raroz28's Avatar
The ground on the passenger side motor mount....
It has a bolt that goes into the mount and the cable is held down with a nut.
The problem is that the nut on top holding down the cable is turning the entire bolt that is bolted into the mount. I really can't think of a way to free just the nut.
I'm sure I'm not the first person this has happened to, so does anybody have any tips? This is the nut.
raroz28 is offline
Old 08-05-2014, 08:55 PM
Prominent Member
GaryDoug's Avatar
Location: Born on the Florida West Coast, now where can I retire?
Re: Tip for stuck ground cable?
You are probably going to need a thin end wrench to hold the bolt "head" between the terminal and the mount. If yours isn't thin enough, unscrew the whole thing until you can get a wrench in there.
GaryDoug is offline
Old 08-05-2014, 08:57 PM
raroz28's Avatar
Problem is though with the cable on there, the cable twists along with it. You can only get 1/4 turn and then it starts to bind. I need to separate the nut from the bolt somehow.
I may have to cut the cable.
raroz28 is offline
Old 08-05-2014, 10:13 PM
Any way to wedge the ground terminal ring? That might help.
shoebox is offline
Old 08-06-2014, 07:53 AM
raroz28's Avatar
Maybe....i will have to try again when I get home. It's difficult to get anything in there. Am I making a mistaken trying to approach this from the front of the vehicle? If I could get an impact on there I could probably get it to yank off.
raroz28 is offline
Old 08-06-2014, 07:58 AM
Have you applied something like PB Blaster?
Injuneer is offline
Old 08-06-2014, 09:51 AM
raroz28's Avatar
Yeah I used "faster." It's the same type of thing. The problem is tho that the bolt that is on the mount breaks loose easily. The nut on top is where the seize is. If I could get a wrench onto the bolt I could definitely get it off but it's too tight f a clearance to get anything on it.
raroz28 is offline
Old 08-06-2014, 11:56 AM
I was thinking the ground strap lug might be easier to break loose if you could jam it, and it had a bit of "lube" on it,.
Injuneer is offline
Old 08-06-2014, 12:13 PM
Mystery Bird's Avatar
I had the same thing happen. Unfortunately mine broke from trying it too many times with different things. I ended up putting on a new connector.
Mystery Bird is offline
Old 08-06-2014, 05:08 PM
pizzi-man's Avatar
take a angle grinder with a thin blade or a hack saw and cut across the top to form a groove for a flat bladed screw driver.
pizzi-man is offline
Old 08-06-2014, 09:52 PM
Prominent Member
GaryDoug's Avatar
Speaking of grinders.... take an expendable end wrench and grind it thinner to get on the "head" of the bolt.
GaryDoug is offline
Old 08-06-2014, 09:53 PM
DocJhn's Avatar
My thought as well Pizza Man, just take a grinder and grind the nut off if you have room!
DocJhn is offline
Old 08-07-2014, 06:51 AM
raroz28's Avatar
There is barely room for a socket let alone a grinder.
I think the best idea thus far is grinding down an expendable wrench to get onto the main bolt. I think I have a 9/16th that I've already hacked up in the past. Maybe that will fit on there.
raroz28 is offline
Old 08-07-2014, 06:53 AM
That's what cheap Chinese wrenches are good for. If it's too tight you may have to bend the head a little too.
Old 08-07-2014, 08:08 PM
raroz28's Avatar
I ended up buying another battery ground cable and running it to the other motor mount. I cleaned it up real nice so the connection should be good.
I figured it wouldn't hurt to leave the other ground connected and just double them up at the battery.
Hopefully this fixes the slow crank when warm issue. I replaced my alternator, added another ground cable, and took my sanding wheel to every last ground connection on the car to where everything is shiny.
If the problem persists, I guess I'll replace the battery.
raroz28 is offline
Quick Reply: Tip for stuck ground cable?
