ticking noise and miss
Old 04-10-2015, 08:09 PM
94Z28LS1toLT1's Avatar
Hey guys here's my issues I have a ticking sound coming from the driver side valve cover it comes when I'm coming to a stop,it will tick for less than a minute then go away and comes back occasionally.
2nd issue is only when I'm on the freeway when I'm around 65 to 75 mph (3k rpm)and keep my foot on the gas like I wanna go faster the car will hiccup/jerk I seen the rpm like kick back. When I go 0 to 50 no freeway mph the car accelerates perfect and powerful.
1.Car fires up fast and stays on idling perfect.
2. Spark plugs, wires,distributed cap and rotor done,fuel filter,ignition module all been changed,I do what could cause this thank you guys
94Z28LS1toLT1 is offline
Old 04-10-2015, 10:28 PM
Re: ticking noise and miss
What does the oil pressure look like as you are coming to a stop? Does the tick get worse on harder stops?
Injuneer is offline
Old 04-11-2015, 09:15 AM
The oil pressure is below 20 coming to the stop and the ticking is worse on harder stops yes
Old 04-11-2015, 09:46 AM
It's like 18 to 19 psi Fred
Old 04-11-2015, 10:09 AM
Just checking to see if it was dropping to "0" which would indicate the oil pump pickup has come loose. Does not appear to be the case. Oil pressure is proportional to RPM.... as RPM drops, pressure drops.
Use a stethoscope to lo locate the specific source of the noise. If it's a valve train component, check the valve adjustment.
You second problem, the stumble when to want to accelerate, will probably take a PCM data log to track down. For now, check for a torn rubber inlet elbow, or the elbow not being fully on the throttle body, particularly at the bottom.
Injuneer is offline
Old 04-11-2015, 06:17 PM
Woo that's good that oil pressure is fine the ticking is coming from the 2 first rocker arms that's closest to throttle.Now how do I adjust the rocker arms without messing them up?and to see if there is play or if they are too loose.Thank you
Old 04-11-2015, 08:35 PM
Hey Fred the red wire behind the alternator that the nut holds,the wire needed a different terminal B.C. between the wire and terminal were pretty loose. I remember when i bought the car the voltage gauge never moved,and after the car gets warm, the gauge moved up and down a lot
Old 04-11-2015, 10:46 PM
https://plus.google.com/photos/109166711352110492281/albums/6136682654127542865?authkey=CMaEy42zhL_V7AE
Old 04-12-2015, 08:35 AM
I don't get any audio on the video, or were you just showing that the rockers are loose?
Use Shoebox's valve adjustment procedure:
4th Gen LT1 F-body Tech Articles
Injuneer is offline
Old 04-12-2015, 12:57 PM
I'm having issues trying to post the video
Old 04-14-2015, 07:19 PM
yes just showing the rockers being loose just found out my lifters are bad on cylinder 1,but do I need to take the intake manifold off and go through the trouble to change the lifters or can I switch oils and motor flush it to get any sludge I think this didn't happen till I used Castrol edge10 30 fully senthentic
Old 04-24-2015, 08:27 PM
Any suggestions please
Old 04-29-2015, 06:21 PM
Just changed oil to 5w 30 valvoline now ticking is gone......so is valvoline better then Castrol edge fully synthetic 1030.hella confused about the ticking problem I had.
Old 04-30-2015, 05:19 PM
blac94Z's Avatar
Lifter is bad in cyl 1
blac94Z is offline
KYWes
06-14-2022 06:52 AM
colts0455
13
08-07-2015 09:15 PM
techstar
08-06-2015 11:20 AM
GT what?
07-14-2015 10:17 PM
colts0455
07-07-2015 07:19 PM
Quick Reply: ticking noise and miss
