Throttle body size
Old 10-23-2010, 11:51 AM
fitz796's Avatar
Throttle body size
I just got a 58mm ported intake manifold for my 95 z28. Before I put it in this weekend I plan on getting a ported throttle body aswell. I can obviously put in put in a ported throttle body up to 58mm that will work with the intake manifold, but I was wondering if I should even consider a 52 or 54mm one instead?
fitz796 is offline
Old 10-23-2010, 12:17 PM
Ricardo's Avatar
If you dont have any additional mods just use the stock throttle body.
If you have ported heads, cam and headers then you should also consider a bigger TB.
Ricardo is offline
Old 10-23-2010, 12:36 PM
fitz796's Avatar
thanks for the feedback. good to know
fitz796 is offline
Old 10-23-2010, 02:31 PM
96capricemgr's Avatar
Also be aware a bigger TB without retuning a A4 car for it will do transmission damage over time.
I would not bother swapping the intake.
96capricemgr is offline
Old 10-23-2010, 02:48 PM
fitz796's Avatar
Sorry for the stupidity but a4?
fitz796 is offline
Old 10-23-2010, 07:18 PM
4-speed automatic transmission = A4. In 93, a 4L60, 94-02 a 4L60E
Injuneer is offline
Old 10-24-2010, 08:06 AM
95Blackhawk's Avatar
Also be aware aftermarket TB's are commonly designed to dump idle air into the main plenum instead of the Idle Air Plenum passages GM designed in our intakes. This screws up your idle. I would be prepared to tune if you want it acting like stock again.
95Blackhawk is offline
Old 10-24-2010, 04:14 PM
fitz796's Avatar
well im not sure if makes a difference but mine is a 6 speed....not automatic
fitz796 is offline
Old 10-24-2010, 05:32 PM
The A4 is shifted by the PCM, based on throttle position, etc. If you alter the throttle body, you alter air flow vs. throttle position, and that throws the shifting off, requiring a reprogram. This is not an issue with the M6 (6-speed manual).
Might want to add a "signature" with basic info about your car - year, model, engine, trans and any major mods. That makes it easier for people to help you.
Injuneer is offline
Peytons'z
05-06-2021 09:25 AM
HectorM52
07-30-2017 11:46 AM
QuickSilver02
04-07-2015 11:12 AM
4586
Parts Wanted
03-17-2015 11:24 PM
07-04-2005 05:00 PM
Quick Reply: Throttle body size
