Those wanting a big cube LTX get in here ASAP!!!
Old 04-11-2009, 12:48 PM
jpack24's Avatar
Those folowing this thread, https://www.camaroz28.com/forums/sho...d.php?t=678840 ,I am putting this up to make sure it doesn't get missed in the middle of a thread.
If you want it, Dart needs to hear from you. On their forum, they now have a topic and poll. http://www.dartheads.com/dartboard/showthread.php?t=930 If you have a LTX and even if you don't plan building one now, this is huge news for us. My block I had is already dropped off to be shipped to Dart for measurements as well as the front cover. Please pass this information on to anyone that you know has an LT engine. The more response to this, the faster it will be made. We are really close to this and we can all thank my engine builder Jerry Clayton for getting this to this point. It is all up to you guys now. This is not a bench racing idea anymore, it is now a reality. Thanks.
jpack24 is offline
Old 04-11-2009, 01:50 PM
bombebomb's Avatar
If they make this, I will
Not saying its not great news, but I personally would not do it.
Going to vote now, they have an option for almost anyone, so I suggest everyone votes.
bombebomb is offline
Old 04-11-2009, 08:02 PM
Boostwhat's Avatar
Although some may see it as a waste of time I personally am pretty f'in excited about this. Imagine a 440" LTX....
Boostwhat is offline
Old 04-11-2009, 08:06 PM
whyrun's Avatar
I'm all for it going there to post my vote right now!! And of course you always got the Debbie downers
whyrun is offline
Old 04-12-2009, 12:32 AM
mad95z's Avatar
I would be very interested. I dont want to register on there site though.
mad95z is offline
Old 04-12-2009, 09:07 AM
Going to be interesting to see what the legal issues are. GM had to stop using the "reverse flow" cooling (ever wonder why the LT1 is the only engine to use it?) because the inventor of Evans coolant has the patent on reverse flow cooling, and won his battle with GM in court. Can someone now build and sell a "new" block that violates the court settlement with GM, or is this just considered a "replacement" block?
Injuneer is offline
Old 04-12-2009, 11:05 AM
87bandit's Avatar
well technically if that were an issue wouldn't there be an issue with companies selling "reverse flow" cylinder heads?
87bandit is offline
Old 04-12-2009, 11:54 AM
bombebomb's Avatar
That is a good question, I never realized it was patented. I always wondered why no one else ever did it. This should pan out to be interesting no matter what happens.
Never got my activation email from Dart forums
Old 04-12-2009, 11:55 PM
I'm not a lawyer, so I don't know the answer. I was just trying to raise a relevant question.
Injuneer is offline
Old 04-13-2009, 01:02 AM
JD311's Avatar
GM used reverse cooling on Pontiac V8's 55-59. They then went to the standard cooling like a sbc in 60-up. Of course when they did it on the sbc in 92 it became the LT1 we all love/hate.
JD311 is offline
Old 04-13-2009, 03:18 PM
whyrun's Avatar
Originally Posted by cardo0
Good point folks.
I see the real marketing compitition as the $1600 LT1's now from GMPP. Heck why buy a $2000 block when u can buy the long block for a lot less. Granted these LT1's GMPP is selling now are likely old stock and supply is limited.
cardo0
The whole point of this block is to run a big bore, were not wanting them to build a factory replacement block. why would I want a factory short block with cast componets? I had an item patented back in 96' and my lawyer told me then that all a compeditor would have to do is change my design by 20% and be with the law, to put it in perspective 20% would equal a change in color..
whyrun is offline
Old 04-13-2009, 04:20 PM
96capricemgr's Avatar
cardo0 you keep talking about a waterpump pulley bypass. Sure some tow package b-bodies got a belt driven fan some of them Roadmasters, BUT they have the same waterpump as all the rest of the LT1s so you are repeately using bad information to try and press your point. That fan is on a seperate bracket, not the pump. Here is the mechanical fan setup, the large black pulley there is a duplicate of in the pic. http://s120.photobucket.com/albums/o...t=DCP_0500.jpg
You state the opti is great for firewall clearance(you are right), BUT this market if full of people who think they need to get rid of the opti to run 11s. I don't agree with them but that is what this market thinks.
It would be nice to see this made but I don't think it is anywhere near as "necessary" as folks want to believe it is. Bad combos are the norm around here and that holds the platform back way more than the block.
96capricemgr is offline
Old 04-13-2009, 04:55 PM
slowride94z's Avatar
aluminum????
wouldnt that be some mud in the ls eye
slowride94z is offline
Old 04-13-2009, 06:16 PM
kgkern01's Avatar
I'm wondering something about the stroke. Looking at the SHP SBC block specs on Dart's website is says this:
Bore & stroke: 4.165” x 3.750” max recommended
Now does this mean that the largest you could go with this would be a 409ci, or maybe 422ci if clearancing for using a 3.875" stroke? Or would it be able to be safely clearanced for 4" or more stroke? I'm wondering if the cam position will limit the stroke to below 4"??? If this block is capable of a 4" stroke, and becomes a reality, then my 385ci build parts will go on sale to help fund building a 427 from this block instead.
kgkern01 is offline
Old 04-13-2009, 07:20 PM
boosted-lt1's Avatar
4" should work
http://www.dartheads.com/dartboard/showthread.php?t=895
boosted-lt1 is offline
Quick Reply: Those wanting a big cube LTX get in here ASAP!!!
