T/A and Camaro Gauge Cluster interchange questions.
#16
Re: T/A and Camaro Gauge Cluster interchange questions.
not to beat a dead horse but can anyone tell me if a speedometer cluster from a 97 TA will work in a 95 TA? Only difference i can see is that the 95 cluster is not digital mileage where as the 97 is....
#17
Not all 97 clcluster usters have the digital odometer. I have a 97 t/a cluster in my 97 z28. Plug and play. You can even swap the odometer mechanism out to retain your cars actual mileage if they both use the old roller odometer. Other than that they are the same exact cluster. You can simply swap just the gauge faces if your doing it just for cosmetic and color purposes. The t/a gauges actually work way more accurately in my car than the original camaro set I took out.
Brandon Wittmer
12-07-2014 12:15 PM
