sweet smell @ startup
Re: sweet smell @ startup
Originally Posted by jeremyferguson
If its coming through the vents inside the car it's probably the heater core....
Is there a way to test the heater core without pulling it out?
Originally Posted by tomatocity
I have a convertible, as you do, and the top is usually down so I don't know if it is coming from the interior. Guess I will put the top up and see if I get the same smell.
JerremyFeguson: "Other than that, the last time I did a heater core was in the 'ole 79 buick regal and I knew it was bad because I had acouple gallons of coolant on the floorboards..."
The last heater core I replaced was on my 1993 S10. That friggin sucked. Remove the stereo, loosen and pry a portion of the dash, can't see nothing, etc.
Nayr
03-03-2023 08:34 PM
