Stock Lt1 deck height?
trying to order pistons to get as low of compression as I can, wondering what the stock deck height is? Is it like -.1? i dont want zero deck, but just trying to figure out what the deck height is
Most say it is .025". I measured mine when I was going to have the block decked and it varied between .024" and .027. When I got the block back and assembled the engine, the deck height was .011" to .012". There must have been some non-flat decks or the decks were out of parallel with the crank.
Jim
Jim
kk, thats what i was wondering. I am looking at just doing a stock rebuild with a balanced rotating assembly using stock crank, forged rods, forged dish pistons, and not having the deck or anything touched, or if i do have the deck touched, i want it to be as minimal as possible
It's a good idea to at least have it decked flat. You want a good sealing surface and from the sound of things you are going FI. You don't want an uneven surface for forced induction. Is that the reason for wanting the lower compression?
Heres my next quesiton i guess
I want to mainly do this as a DIY, and keep as many people out of it as I can.
Now, I know how to put a motor together from rods/pistons/crank, etc.
So, would it be okay to have a machine shop bore it out, and balance it, and me just put it all together, or is that not the best idea?
I would just tear the motor apart, replace the rods/pistons, get it rebalanced, and not bored, but i know the block has 160k on it and at least needs honed lol
sure is.
check the line bore and cyl bores, I think it will need to be bored probly has oval shaped cyl. walls. I would get the to balance etc.
so, basically, have them to the machine work, and then im okay to assemble the shortblock, correct?
10-31-2016 11:09 AM
Brandon Wittmer
12-03-2014 09:28 PM
CobraEatr
07-23-2002 06:32 PM
