Starter indexing
Starter indexing
Hey Guys,
On my 94 lt1 if I click the ignition the starter bendix drive
gear engages the flexplate as it should. However I notice that if I just click the ignition on and off without starting, the small gear does not retract. If I move the flexplate manually it retracts. Is this normal? Hard to see if starter gear is engaged when engine is running. Also tried various shims. Same results.
Re: Starter indexing
You do need to check the clearance, but it's hard to do with a stock starter. A bent standard paper clip is close to the required clearance, and might work.
Courtesy of Shoebox
http://shbox.com/1/starter_gear.jpg
Courtesy of Shoebox
Courtesy of Shoebox
Courtesy of Shoebox
mike24
08-07-2002 10:06 PM
Last of a Breed
05-29-2002 10:31 AM
