Sometimes my car just clicks! and no start
Old 10-22-2003, 06:08 PM
cz28s's Avatar
Ok its happening more and more often now, didnt used to happedn that much at all but now its becoming a slight problem. When i turn the key to start the car sometimes it just clicks and that s all. i noticed that if i wait a little bit after i turn the key to on, it usually turns over and starts up. sometimes i have to o this multiple times to start the car. So im asking you fellas what the prob could be. Im no expert so ya know. but i was thinking coil? you let me know Thanks a million Cory
cz28s is offline
Old 10-22-2003, 06:09 PM
Transamdriver's Avatar
Starter solenoid.
Transamdriver is offline
Old 10-22-2003, 06:17 PM
cz28s's Avatar
oh yah the starter has been replaced already recently
cz28s is offline
Old 10-22-2003, 06:35 PM
blk1994z's Avatar
mine does the same thing, and i have replaced the starter also. Would a heat shield help at all? Im going to put another starter in soon.
blk1994z is offline
Old 10-22-2003, 07:06 PM
cz28s's Avatar
the starter and starter solenoid are the same thing right? or no..
cz28s is offline
Old 10-22-2003, 07:08 PM
No, the solenoid is ontop of the starter. Its the part you hear clicking. People usually just replace the whole thing.
Check the chassis ground wire also.
Old 10-22-2003, 07:38 PM
cz28s's Avatar
como se what??? chassis ground wire? ha ha i have no clue, so theres no way this could be the coil?
cz28s is offline
Old 10-22-2003, 07:43 PM
Jason Dove's Avatar
Check the clutch saftey switch with an Ohm Meter... make sure it has a good connection all the way through the switch's range. (If it's an M6). The car won't start without that connection in place.
Jason Dove is offline
Old 10-22-2003, 07:50 PM
Black94mula's Avatar
Mine does this too, the reason is because the starter is old and their is a bad spot on the windings of the motor. Whenever it does it, I put the car in gear, push the clutch and push the car a little bit in either direction. While its still rolling, i let the clutch out so it moves the motor and therefore the starter to a different position. Embarrassing, yea, but hey. I'll get the LT4 starter someday.
Black94mula is offline
Old 10-22-2003, 08:02 PM
cz28s's Avatar
ok wheres the clutch safety switch and where can i get an Ohm meter
cz28s is offline
Old 10-22-2003, 08:29 PM
93Z286Speed's Avatar
mine does the same thing, i put a new starter in got like 10 starts outta it, and it does it again.. ima put another new starter in this weekend. and check the chassis ground and the wires for the starter real good.. if it happens again has to be the neutral saftey switch OR the Ignition switch.. i dont think its the ignition cuz i hear a clicking around by the glove box (starter solenoid i think) so that makes me think the NSS and ignition switch are good
93Z286Speed is offline
Old 10-22-2003, 09:13 PM
cz28s's Avatar
ok basically what do i need to go visully check? and where in the heck is it?
cz28s is offline
Noenav
03-01-2019 07:38 AM
bfmv13trivium
01-14-2015 09:57 AM
jj71787
12-30-2014 02:15 PM
USAirman93
11-24-2014 03:37 PM
Dave19yz28
01-26-2003 01:45 PM
Quick Reply: Sometimes my car just clicks! and no start
