sea foam
Old 08-05-2016, 05:47 AM
frankrizz's Avatar
sea foam
Hey Members,
Just dropped my oil pan on my LT1 and noticed a lot of
varnish stains on interior block surface. I never used sea foam before, but
do you think this additive is effective on these engines? P.S no other motor
issues at all.
frankrizz is offline
Old 08-05-2016, 09:27 AM
94Z28LS1toLT1's Avatar
Re: sea foam
Originally Posted by frankrizz
Hey Members,
issues at all.
Hmmm not sure I've heard people's different opinions on seafoam,good n bad. In my opinion I don't think too much good things about it
94Z28LS1toLT1 is offline
Old 08-06-2016, 10:17 PM
Fatdog2's Avatar
Re: sea foam
There is a video on u-tube on this when a guy took a brand new lawn mower out of the box and ran sea foam through it.Good watching.If it ain't broke,well you know the rest.(Hope this helps.
Fatdog2 is offline
Old 08-07-2016, 06:50 PM
gaedbo's Avatar
Re: sea foam
There is a pretty good video by Chris Fix on YouTube where he uses a camera to look into the cylinders to see the results.
gaedbo is offline
Old 08-20-2016, 08:00 PM
traviscox's Avatar
Re: sea foam
you can take seafoam and unplug brake booster let it suck from there and it cleans the upper system valves etc works very well
traviscox is offline
Old 08-20-2016, 08:01 PM
traviscox's Avatar
Re: sea foam
also they make a slugde cleaner forgot the name will have to check tomorrow but it is awesome you pour in run engine at idle then change oil but works wonders seen with my own eyes but if engine has a lot of sludge it can clog the oil screen
willismoons
05-27-2015 04:03 PM
dylan1303
05-22-2015 12:24 PM
SergheiS
04-26-2015 08:15 PM
asianice25
06-21-2002 11:55 AM
Quick Reply: sea foam
