Rocker arms wont stay tight
Old 08-27-2005, 02:37 PM
$hawn's Avatar
I have the comp cams pro magnum rocker arm and when I turn the engine over the ones that I just adjusted come right off the valve and pushrod but the nut is tight. What could be wrong?
$hawn is offline
Old 08-27-2005, 04:11 PM
Re: Rocker arms wont stay tight
Lifters collapsed or your not adjusting them correctly.
shoebox is offline
Old 08-27-2005, 04:41 PM
Colin91Z's Avatar
$hawn, I have done this may times, if you want I could stop by and see if I can help you figure out what the problem is. You still have my cell # right?
Colin91Z is offline
Old 08-27-2005, 06:34 PM
$hawn's Avatar
Hears the deal, I put new heads and thinner head gaskets, so at first I used stock lenght pushrods, there too long but I had them adjusted fine, then I put some shorter pushrods in and the car woudnt stay running. Figured out that the rockers arent staying tight after I adjust them, I turn the motor over and the ones I did are real loose. The lifters I cant push in with the pushrods by hand so they seem to be pumped up, I think.
$hawn is offline
Old 08-27-2005, 06:40 PM
You should not change pushrod length unless you have determined that you need it to maintain proper geometry.
shoebox is offline
Old 08-27-2005, 07:04 PM
$hawn's Avatar
Right, I used a pushrod lenght check, I didn't mean for it to sound as if I just put in some shorter ones laying around.
$hawn is offline
Old 08-27-2005, 09:24 PM
Good. It's always helpful to have all the info.
shoebox is offline
Old 08-28-2005, 07:43 AM
slopokrodrigez's Avatar
What's the part number of the rockers you used?
slopokrodrigez is offline
Old 08-28-2005, 09:04 AM
$hawn's Avatar
The 1305, 1.6 7/16 non self aligning.
$hawn is offline
Old 08-28-2005, 09:23 AM
30696bird's Avatar
I used the same ones. Did you get the guide plates? I had no issues with mine. You ought to have colin91Z come over and help you out.
30696bird is offline
Old 08-28-2005, 06:18 PM
So do you have guide plates?
Old 08-28-2005, 07:55 PM
$hawn's Avatar
Yes I have guide plates, once I pulled my head out of my butt, I got it, I think the problem was I didnt adjust some of them at tdc, and once I turned the motor over they were loose, but I got some help to watch the valves this morning and got it figured out.
$hawn is offline
Old 08-29-2005, 02:19 PM
Not to beat a dead horse but you did get hardened pushrods to use with the guide plates didn't you?
Old 08-29-2005, 10:54 PM
$hawn's Avatar
Yes sir.
$hawn is offline
Old 08-30-2005, 06:42 AM
cehan's Avatar
I understand that the standard SBC guide plates aren't properly spaced for LT1's and will cause the roller rocker to ride offcenter on the valve stem. The ones to use are the GMPP p/n 14011051.
Chris
cehan is offline
69z-28
01-29-2016 10:46 PM
KamikaZ28
05-28-2015 12:45 AM
Sauced
04-12-2015 10:18 AM
carl.froehlich
03-13-2015 12:38 AM
Brandon Wittmer
12-07-2014 12:15 PM
Quick Reply: Rocker arms wont stay tight
