Rim Locks?
Re: Rim Locks?
I know someone makes some sort of socket specifically for getting those off without the key. Do you still have that paper with the serial # on it? You could have a new one sent to you.
Other methods aren't so pretty. You can try banging a slightly oversize socket on and using an impact wrench to get them off, but you might destroy sockets, or you can use a cutoff wheel and just go through them- just don't go through the studs...
Re: Rim Locks?
I suggest trying for a couple hrs to remove them with vice grips which will be pretty much like pissing into the wind. Then i would go get my Summit catolog and order the special socket they have to remove locking lug nuts with out a key.
Aaront810
08-29-2020 09:34 PM
