Replace struts? - CamaroZ28.Com Message Board
Reply
Thread Tools Search this Thread
Old 10-29-2003, 11:36 AM   #1
Red96Lt1's Avatar
Replace struts?
How hard is it to repace all for struts? I was thinking bilsteins. Any suggestions?
Red96Lt1 is offline   Reply With Quote
Old 10-29-2003, 11:40 AM   #2
Super Moderator
We have four "shocks"..... no struts .
Shock/Spring Install
Back shocks are 15-minutes each. Fronts require a spring compressor, and can take 1 to 2 hours each.
Injuneer is offline   Reply With Quote
Old 10-29-2003, 11:58 AM   #3
It's an easy job. If you ever thought about changing your springs, that would be the ideal time to do it. The Bilsteins are a great choice.
carlos64030 is offline   Reply With Quote
Old 10-29-2003, 03:13 PM   #4
Red96Lt1's Avatar
Do springs wear out? And how critical is it to repace them?
Old 10-29-2003, 05:32 PM   #5
Red96Lt1's Avatar
Is there more than one type of Bilstein shocks for a camaro? Also, where would you buy them? Thanks!
Old 10-29-2003, 06:17 PM   #6
The front shocks can be a b-tch to replace sometimes because the nut at the top usually corrodes to the point where you need to cut it off.
1fast95Z is offline   Reply With Quote
Old 10-29-2003, 06:20 PM   #7
buy them at bimmerparts.com
BMC95TA is offline   Reply With Quote
Old 10-30-2003, 12:22 PM   #8
Red96Lt1's Avatar
Is there more than one type of Bilstein for a camaro?
Old 10-30-2003, 01:19 PM   #9
Yes, springs can wear out and it will cause the ride to be really rough. Bilsteins are probably the best shock for our cars. My friend just replaced his shocks/springs on his 95 t/a with the OEM and his car rides amazing, its not rough at all.
Kataklysm is offline   Reply With Quote
Old 10-30-2003, 01:22 PM   #10
we have 2 rear shocks, and 2 front Struts...
SlowAssTA is offline   Reply With Quote
Old 10-30-2003, 01:45 PM   #11
Super Moderator
Quote:
No...
We have an unequal a-arm front suspension, with "coil over" shocks. They are not struts.
3rd Gen F-Bodys have "struts"...... Mustangs have "struts". 4th Gen F-bodys have shocks.
Old 10-30-2003, 02:15 PM   #12
Red96Lt1's Avatar
No...
What's the difference b/t shocks and struts?
Old 10-30-2003, 02:23 PM   #13
stereomandan's Avatar
The coilover shock in front have the spring around the shock. Part of the shock actually holds the spring in place. The shocks in the rear are totally separate from the springs.
The rears are easy to change. I changed all 4 shocks and the front ones took about 5 hours and the rear ones about an hour. Have something ready so you can cut the top nut off the shocks in front. My driver side was o.k., but the passenger side was rusted tight. A hacksaw won't do it. You can't get the right angle. You need some kind of grinder. I used a dremel but it took FOREVER.
You also need a spring compressor and a torx bit for the bolts on the shocks in front. Have a friend help.
Dan
stereomandan is offline   Reply With Quote
Old 10-30-2003, 02:36 PM   #14
how easy is it to dot he fronts really? Is this something I should consider doing myself or would it be more price effective to just have a shop do it?
phrozen is offline   Reply With Quote
Old 10-30-2003, 02:39 PM   #15
My shop quoted me about $150 to do the front install. I did it for free. It's time consuming, and kind of a pain. If you want to see exactly how your front suspension works, do it yourself.
Let me put it this way, it wasn't worth loosing $150 that I could spend on other mods. Autozone has free lender spring compressors. The torx bit was a few dollars.
Dan
Reply
Thread Thread Starter Forum Replies Last Post
Front strut replacement help '95 Z28 KYWes Suspension, Chassis, and Brakes 4 04-03-2015 08:59 PM
New girl with new car and new problems Magenta_Hearts New Member Introduction 4 03-25-2015 11:24 AM
ballin a budget, Struts? Magenta_Hearts General 1967-2002 F-Body Tech 1 03-22-2015 03:44 PM
1990 Camaro IROC-Z dale3in98 Cars For Sale 0 02-14-2015 01:18 PM
Tower Strut Bar w/ ASR? 1996LT1Z28 Suspension, Chassis, and Brakes 5 01-14-2015 09:09 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
