car dies
Old 10-28-2003, 01:28 PM
WhoomWhaatWhaah's Avatar
car dies
Today I drove about 20 miles(thats far) and on my way home everythings peachy. Soon as I get off the freeway the car bogs like it's going to cut off, so I let her Idle to the gas station cause I did the same thing when I'm outta gas. Fill up time, Take off from the station but the car wants to die when I give it gas, but she'll idle fine. I had just got off the freeway cruising at about 85. What going on whith my car. It think it might be the intake air sensor, I hope it's not a opti.
WhoomWhaatWhaah is offline
Old 10-28-2003, 01:39 PM
teke184's Avatar
try unplugging the maf sensor, had a similar thing happen to me and it was a faulty maf.
unplugging it sends it into limp home mode or something...and if it runs good unplugged you know what's the culprit
and befor anyone says "he has a 93"
i'm guessing since it's a later motor he has a maf on it now
teke184 is offline
Old 10-28-2003, 01:55 PM
I kept my 93 intake and computer. I am M.A.F. free.
Scanned car and I have no codes. I wish now that I would have used to 95 setup(computer and intake). Obd2 has the ability to store soft codes and trips, unlike obd1 that will only save major codes.
Old 10-28-2003, 02:32 PM
teke184's Avatar
bang bang bang...
shot down again...i tried
cough cough opti
teke184 is offline
Old 10-28-2003, 02:39 PM
Terran2k's Avatar
might also want to make sure its not a clogged CAT
Terran2k is offline
Old 10-28-2003, 03:21 PM
how can i check for a clogged cat, I have an extra one. I hope it's not the opti I can't afford it right now.
Old 10-28-2003, 06:52 PM
cleaned air intake sensor and map sensor on manifold with crc brake parts cleaner, car runs hard and strong. Do I need a new sensor cause I don't want this to come back
Old 10-29-2003, 09:37 AM
problem came back.
Old 10-29-2003, 09:39 AM
IXLR894Z28's Avatar
Fuel pump?
IXLR894Z28 is offline
Old 10-29-2003, 02:28 PM
tryintogofast's Avatar
How old is the fuel filter on your car? I had a problem like yours cause the previous owner didn't change it for about 50,000 miles that bastard.
tryintogofast is offline
Old 10-29-2003, 03:35 PM
Monitoring it with a scan tool may be the best way to track it down. Checking the fuel pressure would not hurt, either.
shoebox is offline
Old 10-29-2003, 10:44 PM
i changed the fuel filter about 5k ago, i heard i could get an opti from autozone w lifetime warranty for 130, it this true?
Old 10-30-2003, 01:27 AM
stillsprayin's Avatar
yea you can get an opti complete for 130 with an 85 core charge
stillsprayin is offline
Old 10-30-2003, 09:35 AM
I'll swap the opti next week, I hate this Car. A good lawyer could get us some money from gm.
Old 10-30-2003, 03:41 PM
1FstFormulaV8's Avatar
Hesitation
I'm having the same exact problem with my 1993 Formula. It idles fine but once I start moving it really gets jumpy and almost doesn't move.
I'm thinking it's the opti. I just got a full service, new plugs, fuel filter, pcv valve, plug wires, and got the fuel pressure tested. It was within tolerance level. And it stopped for about 3 weeks and now the problem is back. I also have a very foul exhaust odor. What do you guys think?
1FstFormulaV8 is offline
Quick Reply: car dies
