Removing the Intake
Removing the Intake
For those of you who have or know, i was wondering how much of a PITA it is to pull the intake manifold off? what all has to be removed other than the obvious...fuel rail, injectors, throttle body? Also will i need to replace a seal? thanks guys
Re: Removing the Intake
Look on my Tech Page for the cam removal "How To". It shows how to remove the intake. It's not that hard. You will need new gaskets. The fuel rail is a little different on a 1993.
Originally Posted by Lt1t56
Dont have to remove throttle body to remove intake.
Just make sure you seal the front and back gaskets good. It shows you on Shoebox's website. I have pulled mine off about 7 or 8 times.. for different reasons and out of those about 3 have leaked. youd think id get the hang of it.. I used ultra grey once and it leaked aswell as ultra black, now I use ultra copper and havent have a problem. Make sure you load it up and make an even bead accross both seals and in the corners of the head and block.
Henson071
05-04-2015 12:23 PM
